586,329 active members*
4,864 visitors online*
Results 1 to 14 of 14
    May 2009
    1332
    Temperature Indicator Wiring
    Got this gadget to show the Spindle cooling water temperature in my cnc but I don’t understand the 12VDC power wiring connections.
    Do I connect the 12vdc to terminals 3/4 and the switch in terminals 1/2 is wired internally or I connect the 12vdc as shown in the attached PDF?
    And polarity? Does it matter which terminal I connect the pos / negative?
    Nicolas
    24221
    Re: Temperature Indicator Wiring
    It appears to allow 12v DC or AC input, most likely has steering diodes internally.
    In that case, if using DC you can connect it either way to 3 & 4,
    Term. 1 & 2 are the N/O contacts of the relay. so you can use these to switch what ever circuit you need to, as long as it does not exceed the current rating of the relay.
    It is a thermostat, so it switches on off at the set temperature. using the NTC terminals
    Albert E.
    May 2009
    1332
    Many thanks Al
    Nicolas
    Nov 2012
    1267
    As Al said, 12V can be connected either way to terminals 3 and 4.
    The relay contacts (terminals 1 and 2) I personally would wire to the safety/E-Stop circuit so the machine would turn off if the coolant overheats. If you have a normally closed E-stop mushroom (and you should!), you can wire the relay contacts in series with it.
    May 2009
    1332
    Very good idea CitizenOfDreams, thank you
    I was thinking about it and I do have a mushroom type E-Stop but for now terminals 1 and 2 are not connected because I only run the spindle not more than 14K RPM and not for long cuts. Spindle has always been cool to the touch. I will complete the wiring soon (to the E-Stop).
    When I first connected the unit (just happened NEG was at terminal 3 & POS at 4) it didn’t work (the screen was black) and I thought I did something wrong but I didn’t find anything wrong. Then I switched the power supply so the POS was at terminal 3 and NEG at 4. Then the screen became alive. Means terminals 3/4 are polarized as per my experience.
    Nicolas
    24221
    Quote Originally Posted by kolias View Post
    That reflects on the instructions being very poor then, IMO.
    Albert E.
    May 2009
    1332
    The instructions are the worst I have seen BUT the package was shipped from UK!
    Nicolas
    Nov 2012
    1267
    That means the thermostat has a half-wave rectifier, as opposed to a full-wave bridge. Wrong polarity will not damage it, it just won't turn on (as you have observed). Now take a red marker and draw a "+" sign above terminal 3 for future reference. :wave:
    24221
    Things must have gone south there since I left !
    Albert E.
    15362
    As Per the wiring diagram 1/3=+ Load and Negative is 4- it clearly shows which is the load connection
    Mactec54
    24221
    That is only when you use the supply for the load also,, the main issue is/was that the instructions do not state the polarity of 3 & 4 !
    As usual Chinese :"directives"??
    Albert E.
    15362
    Does not have to say what the polarity is, the way it has been drawn is how the 12v+ would be applied the Relay switch is a good indication, load is normally switched this way, schematics / drawings are good
    Mactec54
    24221
    I am used to, and expect clear and precise instructions, perhaps that is foolish of me!
    If in fact the supply input is polarity conscious then it behoves the manuf. to specify it .
    There is nothing clear about that device manual that a little simple concise labeling or explanation would have explained right away.
    Unfortunately it is something that one has to expect as normal from Asian sourced equipment :tired:
    Albert E.
    15362
    There is very little that is not made in other countries, it just depends more on the manufacture, whether it is just a hole in the wall back yard place or a brand name as to the quality and presentation of the product, if you buy cheap then there may be some head scratching.
    Mactec54
  1. COAXIAL INDICATOR
    By tjd10684 in forum MetalWork Discussion
    Last Post: 01-18-2019, 12:51 PM
  2. First Test Indicator
    By Atomic_Sheep in forum Calibration / Measurement
    Last Post: 06-02-2018, 10:09 AM
  3. Coaxial Indicator
    By smokediver576 in forum Tormach Slant Lathe
    Last Post: 07-31-2016, 03:48 AM
  4. wiring diagram for indicator LED/light for limit/homing switches
    By texasdude in forum CNC Machine Related Electronics
    Last Post: 04-28-2014, 05:32 AM
  5. Replies: 11
    Last Post: 02-28-2010, 08:33 PM
