586,082 active members*
3,905 visitors online*
IndustryArena Forum > MetalWorking Machines > Tormach Personal CNC Mill > Tormach PathPilot™ > 4th axis brake and LOCKING_INDEXER functions
    Jun 2022
    Has anyone been successful in using GPIO to control an A axis brake? It looks like I could set an open/unmapped GPIO pin into output mode and then connect the digital output to the hardware pin.
    Anyone’s experience with this and any HAL changes would be greatly appreciated.
    Re: 4th axis brake and LOCKING_INDEXER functions
    Use AC servo motor and AC servo driver for 4th axis can do the job.
    http://cncmakers.com/cnc/controllers/CNC_Controller_System/CNC_Retrofit_Package.html
    Jun 2022
    An AC servo motor of the same size will have less torque at 0 RPM than a stepper. I could always oversize the motor but let's focus on the brake/locking_indexer implementation topics.
    Attached Thumbnails Attached Thumbnails motionsolutions-servo-vs-stepper.jpg
    Apr 2013
    1788
    More expensive but why not use the Tormach USBIO unit? That should work with no HAL or PP changes.
    Jun 2022
    Quote Originally Posted by kstrauss View Post
    ...Tormach USBIO unit? That should work with no HAL or PP changes.
    I'm not familiar with the USBIO but it looks like you can call M64/65 to switch the relay directly. If this is the case, that would be much easier than modifying PP.
    If there are empty GPIO pins on the Mesa board it would also be nice to just be able to use those.
  1. 4th axis air brake
    By dbunyip in forum Haas Mills
    Last Post: 05-08-2022, 10:54 PM
  2. DIY 4th Axis with Brake - The Build
    By mukanico in forum CNC "do-it-yourself"
    Last Post: 02-15-2020, 06:42 PM
  3. Z axis has a brake - adding a limit switch to activate the brake
    By KipKirol in forum CNC Machine Related Electronics
    Last Post: 11-16-2017, 11:31 PM
  4. 4th Axis Design, Disk Brake Calculations
    By tjschweizer in forum Mechanical Calculations/Engineering Design
    Last Post: 09-25-2014, 09:38 PM
  5. brake on 4th axis DX32 control
    By Gncc50 in forum Bridgeport / Hardinge Mills
    Last Post: 04-14-2007, 11:45 PM
