586,119 active members*
3,652 visitors online*
Results 1 to 7 of 7
    Dec 2012
    71
    Yang SMT500 - Lost paramaters
    I bought a second hand SMT500 a year ago. When I received it, I backed up all the files. We are 3/4s the way through a full refurbishment and I wanted to test the limit switches. Unfortunately, it has taken that long that the batteries did not keep the settings.
    I cannot find where I stored my backup of the data. Can these files be recreated ?? I hope so.
    Thanks Wallace.
    Dec 2012
    71
    Re: Yang SMT500 - Lost paramaters
    I have a complete printout of the Parameters - About 6000 lines of data. I also have screen shots of the XY and Z settings.
    I have OCRed the printout and now it is in a text file. Any idea on the next step ?
    Dec 2012
    71
    I've made some progress and found a lot more info in the manuals, but getting the machine to 'recover' from memory loss is a issue.
    It has a Fanuc O-MD controller. After boot I have some of the screens, but it looks like, unless some of the parameters are manuall set, some functions are not working. Eg read from the serial port and mode keys etc.
    I have found parameters on setting the serial port, but, the hard edit key does not light and I beleive that I need to have the machine in edit mode before it will talk RS232.
    Any suggestions ?
    Dec 2012
    71
    A nice member from Canada talked me through entering the 0900-0950 parameters. Once these were entered, the machine had a big wake up.
    All the button and screen options came alive and I can do a lot more now. I have a few alarms to sort out. I presume these are incorrect parameters and I'm hoping I can download the file I have into them machine ignoring the alarms.
    May 2016
    526
    Do you have the diagnostic files as well?Machine will be useless without them
    Dec 2012
    71
    I have a parameter printout
    The numbers go from
    N0001- N0879
    N0900- N999 (special paramaters i beleive)
    N1000- N1128
    N2000- N2128
    N3000- N3128
    N6140- N6979
    N8100- N8399
    I also have Variable settings values
    D300 - D395 Timer settings going in steps of 5
    D501 - D520 Tool Number
    D450 - D474 PC Counter
    D560 - D565 Keep relay
    I also have 2 macro functions, one for auto tool change and one for manual.
    I hope this is enough.
    PS Anyone know of one of these running, please let me know.
    Thanks Wallace
    Hello Wallace,
    I am also based in Nz, i have one of these partially running, lost only a few perimeters, I am very keen on your list, Ill pm you too cheers
    Chris
  1. YANG SMT 500 PARAMETER LOST ANY CAN HELP
    By saul in forum Uncategorised MetalWorking Machines
    Last Post: 01-05-2023, 03:09 AM
  2. Replies: 2
    Last Post: 10-27-2015, 04:53 PM
  3. bp interact 1 paramaters HELP!!!!!!!!
    By gp8787 in forum Bridgeport / Hardinge Mills
    Last Post: 08-24-2011, 03:06 PM
  4. looking for paramaters
    By slrpfi in forum Want To Buy...Need help!
    Last Post: 02-20-2009, 04:15 PM
  5. I need Two Paramaters for 6M Control
    By 6105Moss in forum Fanuc
    Last Post: 01-24-2006, 09:46 AM
