586,106 active members*
3,142 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > How do I reset the encoder on my okuma MC-4VEA with a 5020m Controller
    Jan 2023
    6
    Unhappy How do I reset the encoder on my okuma MC-4VEA with a 5020m Controller
    I need to get this machine to work, I believe I need to reset the parameters and I can make it to that screen but I cant move the x or y axis and I do not know the process of resetting the parameters. I am completely new at this.
    Apr 2009
    1262
    Re: How do I reset the encoder on my okuma MC-4VEA with a 5020m Controller
    In your System Parameters, you need to go to the PR Zero Offset and shift the encoder position by the amount that you are off. It will give you a "Power on effective parameter set" alarm which requires a reboot. Once you do that, you will be in the new shifted position.
    It's a good idea to write the number down first so that you can go back to it if you go the wrong direction.
    Best regards,
    PS> Your original Parameters for stroke, Zero, etc. should be in the back of the machine in the electrical cabinet recorded on the Management data card for reference.
    Experience is what you get just after you needed it.
    Aug 2019
    29
    hi
    Please send a private massage to solve your problem.
    thanks
  1. Okuma MC-4VAE with 5020m Controller
    By SelchertPW in forum Okuma
    Last Post: 03-14-2023, 05:15 PM
  2. okuma 5020m 4th axis help
    By msherman in forum Okuma
    Last Post: 01-23-2019, 10:08 PM
  3. Okuma osp 5020m to pc
    By hondarider218 in forum Okuma
    Last Post: 04-18-2014, 06:46 PM
  4. Replies: 5
    Last Post: 09-13-2013, 05:03 PM
  5. Okuma 5020M language change
    By greenery_fr in forum Okuma
    Last Post: 10-02-2009, 06:03 AM
