586,104 active members*
3,403 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > Changing the Coolant Through Filter
    Oct 2006
    143
    I can't find any info in the book and I don't want to break it. I assume it screws together; I can't make it budge. Can someone elaborate on how to open this up?
    Don
    Oct 2006
    143
    Anybody???
    Jul 2005
    100
    coolant filter
    The filter can is held on to the housing with a draw bar. The nut is on the back side of the casting. I change the filter every time I clean the sump. It is a standard string wound filter. A few bucks each from McMaster carr.
    Oct 2006
    143
    Thanks a million! That was what I needed. Mine is mounted vertical so the nut was on top; but at least I was able to get it open.
    Don
  1. Filter Question
    By totalfab06 in forum Waterjet General Topics
    Last Post: 03-10-2007, 02:02 AM
  2. arc and nurb filter
    By camtd in forum Surfcam
    Last Post: 07-25-2006, 01:48 PM
  3. Self cleaning Filter
    By Rance in forum DIY CNC Router Table Machines
    Last Post: 01-18-2006, 06:58 PM
  4. Calculating Filter Capacitance
    By CapnC in forum CNC Machine Related Electronics
    Last Post: 01-05-2005, 01:40 AM
