586,117 active members*
3,388 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Having trouble figuring out what is causing the alarm with my cnc lathe
    Post Having trouble figuring out what is causing the alarm with my cnc lathe
    Hi, I'm pretty new to doing maintenance on Okuma machines. so I've been getting the alarm EC Overload Alarm-A 1707-1 and when I look at the manual, It says that the overload relay is tripped. so I reset the overload relay and see if the motors are working normally. I also took the motors apart and cleaned them just to make sure they were okay. They were running pretty well for a while until the alarm showed up again.
    Has anyone had a similar experience? I would greatly appreciate your help
    Apr 2009
    1262
    Re: Having trouble figuring out what is causing the alarm with my cnc lathe
    EC overload alarm is caused by the relay tripping. Which relay is usually an indicator of what device has the problem. Plugging a vacuum cleaner into the 120v 2a outlet on the machine can cause this alarm for example.
    Which relay tripped?
    Experience is what you get just after you needed it.
    Aug 2019
    29
    hi
    Please send a private massage to solve your problem.
    thanks
  1. Replies: 4
    Last Post: 02-17-2013, 04:56 AM
  2. Need helping figuring out CNC issue
    By Eddieman in forum DIY CNC Router Table Machines
    Last Post: 03-10-2011, 07:02 AM
  3. Replies: 6
    Last Post: 08-14-2009, 01:22 AM
  4. Ikegai AX20Z CNC Lathe trouble
    By motter71 in forum Uncategorised MetalWorking Machines
    Last Post: 07-27-2009, 10:49 AM
