586,094 active members*
3,747 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > determining Power and ground wires on a linear encoder /scales
    Mar 2004
    136
    Hi to all,
    After some help in determining which are the ground and power wires on this Linear Encoder / scales
    If someone cold help , i would be much appreciated.
    here are some photos.
    Nov 2012
    1267
    Re: determining Power and ground wires on a linear encoder /scales
    The ground and power wires should have a direct connection to the L393 (=LM393) chip. Check that with an ohmmeter. Pin 4 of the chip is ground, pin 8 is power.
    Normally, wire colors for ground and power would be black and red respectively. Unfortunately, it's not a 100% guarantee - some engineers are quite creative when it comes to wire colors and other conventions.
    Mar 2004
    136
    Thanks so much for your reply , and information
    Very much appreciated
    All working now
  1. Determining correct wires from stepper motor
    By CAD226B in forum Uncategorised CAD Discussion
    Last Post: 07-23-2021, 04:27 AM
  2. Size for ground wires
    By millhouse_ in forum DIY CNC Router Table Machines
    Last Post: 10-07-2019, 07:09 PM
  3. Need help determining coil connection wires
    By mulligan in forum Stepper Motors / Drives
    Last Post: 03-02-2008, 05:53 PM
  4. linear encoder wires ??
    By elpete0068 in forum CNC Machine Related Electronics
    Last Post: 06-26-2007, 04:38 AM
