586,077 active members*
3,623 visitors online*
Results 1 to 11 of 11
    Sep 2014
    28
    Black Conduit tubing Brand
    Looking for the brand name of conduit tubing used in Multicam CNC machines. Mine is a 1999 MG 103. They are high quality and I need to run a new tube. I'd like to use the same brand/type. To be clear this is the conduit running from the machine to the control main panel.
    24221
    Re: Black Conduit tubing Brand
    Do you mean Metallic Flexible conduit?
    I use this extensively and it is available usually from any local electrical supplier, including the necessary fittings, the nice thing is you can run it with MTW or THHN wiring.
    Albert E.
    Sep 2014
    28
    No this is black plastic type, very rugged (it may be wire reinforced, not sure on that). I remember reading a Multicam post about it but I cannot find it. In attached photo it is conduit I am referring to.
    24221
    The type I use appears the same but has a flexible metalic conduit under the plastic cover, if it is not required to be constantly flexing then I prefer this due to its inherent shielding qualities.
    The end conduit fittings can also be used with MS style adaptor fitting. If needed.
    Albert E.
    15362
    Quote Originally Posted by district7 View Post
    What most are using is this PMAFLEX or similar there are a few different manufacturers, it comes in two Profiles T and G
    https://www.igus.com/info/energy-cha...ble-protectors
    https://www.igus.com/iPro/iPro_01_00....htm?c=US&l=en
    Mactec54
    15362
    The Shielding is only as good as who installs it. the Metalic Shielding part has to be correctly Terminated for it to have any affect.
    The Liquatite® Flexible Electrical Conduit does not have a flex rating suitable for CNC machines moving axis, it is very good for nonmoving wire Cable protection though.
    Mactec54
    Sep 2014
    28
    I am running Clearpaths and my spindle cable is an Igus motor cable, so in theory there isn't much noise (they are in a preexisting conduit). This new conduit would be mainly for 24v powered buttons and solenoids (they have flyback diodes on them). It is just running from the Control panel to the machine itself.
    24221
    [QUOTE=mactec54;2537446]The Shielding is only as good as who installs it. the Metalic Shielding part has to be correctly Terminated for it to have any affect.
    For terminating in metallic enclosures each end, the shield earth is terminated each end automatically via the manuf. proper fittings used in the installation.
    Presumably those doing the installation are qualified! in the products use.?
    Albert E.
    24221
    The flex conduit shown does not appear to be as sturdy as the flex metallic conduit, if minimum flexing is going to occur, I would prefer that use that product, if for no more than added protection.
    Albert E.
    Sep 2014
    28
    I can stand on it and it doesn't budge. I am 200+ lb.
    15362
    Then use the Liquatite® Flexible Electrical Conduit
    Mactec54
  1. How to tell the difference in Black ABS VS Black Delrin?
    By conceptmachinin in forum Material Machining Solutions
    Last Post: 10-17-2011, 03:43 PM
  2. Flexible conduit connectors?
    By SPEEDRE in forum CNC Machine Related Electronics
    Last Post: 02-05-2008, 03:18 PM
  3. Need Flexible Conduit Fittings
    Last Post: 02-01-2008, 06:35 PM
  4. Conduit
    By Tom Brown in forum DIY CNC Router Table Machines
    Last Post: 09-24-2006, 04:14 AM
  5. emt conduit, galvanized pipe or black pipe?
    By JohnG in forum DIY CNC Router Table Machines
    Last Post: 05-22-2006, 02:24 AM
