586,108 active members*
3,100 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Okuma OSP-U100M Communication Parameters
    Jan 2023
    Hello,
    We have an Okuma MA-40 with an OSP-U100M control. We are able to upload and download programs successfully, but when we send it to the PC it puts an extra carriage return after each line. We have several other Okuma lathes and mills, but we have set the (EOL) parameter to LF only. The manuals for this U100M control don't show any parameter that we can set for End of Line (EOL). We do not have DNC options on this machine, so we can only set Word, Long Word, Bit parameters. Can anyone help us?
    Jody
    May 2012
    35
    Re: Okuma OSP-U100M Communication Parameters
    Parameter #9 (EOR code) - set to 0 (means CR + LF).
    AGG Software. DNC Precision and CNC Syntax Editor software.
    Apr 2009
    1262
    Try to open it with different word processors. Sometimes notepad will open it without the extra lines when wordpad or word will add them in.
    Experience is what you get just after you needed it.
    Jun 2015
    4154
    hy if you can not solve for the eol chars, i can help you fix the files automatically, once they are inside your pc, with a custom app
    it will work in background, you will not even know it is there / kindly
