586,106 active members*
3,021 visitors online*
Results 1 to 1 of 1
    Jan 2023
    k40 engraving twice
    Hi, I recently bought a k40 laser. After the initial setup I started to make some work tests. Initially the machine was cutting well (apparently), but after some mirrors alignment I made the machine started cutting with errors in the first pass. When I choose multiple passes in K40 Whisperer, the first line is always misaligned. I put here a photo of the problem. Anyone know how to fix it? Thanks in advance
