586,525 active members*
3,393 visitors online*
IndustryArena Forum > CAM Software > Uncategorised CAM Discussion > Enroute 3 Users - I need help!
    Mar 2004
    847
    I am trying to cut a 2" OD x 1" H hemisphere out of 1" Corian. No matter what I do I cannot get it to cut the full 1" depth and it has been cutting my 2" OD to 2 1/2" OD. This enroute software is very fustrating.
    FYI - We are using a 1/2" Ballnose bit. I've tried lying about the material thickness, still doesn't cut the full depth.
    Check Out My Build-Log: http://www.cnczone.com/forums/showthread.php?t=6452
    Aug 2007
    88
    Are you Just looking at it in the preview or when you go to cut it it wont do it. I know i have to ajust the max depth on my router to make it cut the full 1 inch be cause the materal wont be quite an inch
    I'm young and I'm just trying to learn from people that know.
    Mar 2004
    847
    Quote Originally Posted by trooper55 View Post
    Both, in the preview the toolpaths don't go all the way to the bottom of the material and when we cut it it's stopping 1/4" short of the bottom. We cut through 1" and thicker material all the time and never have a problem cutting through, only have this problem when doing a relief for this sphere.
    I even tried lying to the machine and telling it that the material was 1 1/2" thick and to cut the full 1 1/2" - but it still only cut 3/4" into the stock.
    Mar 2008
    6
    Hi Java
    What machine are you using
    Have you set the tool parameters in the tool library for the cutter, diamater as opposed to circumference
    On our Tekcel there are two ways to set the bed height on the motion controller if this is wrong a full cut may not be possible or worse bye bye bed,hope this helps
    Mal
  1. Enroute 3 to generate files for Mach 3
    By edmond in forum Uncategorised CAM Discussion
    Last Post: 08-20-2011, 09:52 PM
  2. enroute pro 3.3 post for fanuc 0Mb needed
    By goodplastics in forum Uncategorised CAM Discussion
    Last Post: 08-08-2007, 05:47 AM
  3. Enroute Pro-Wood
    By tea-n-elle in forum Uncategorised CAM Discussion
    Last Post: 05-01-2007, 03:57 PM
  4. Enroute 3d Software with plasma?
    By alcoa65 in forum Uncategorised CAM Discussion
    Last Post: 05-12-2006, 02:44 AM
  5. Anyone using Enroute
    By cncadmin in forum Uncategorised CAM Discussion
    Last Post: 05-28-2003, 06:08 PM
