586,100 active members*
2,676 visitors online*
    Jul 2007
    18
    retrofitting CNC lathe
    I am repairing cnc press brakes, shearing machines and turret punch press. I retrofit Press brakes.I have not retrofitted any lathe.I want to retrofit my lathe.I want to know from where can I get a list of controller suppliers for CNC lathe.Is there any source from where I can get technical information of controller and study it? Which are the best models from Fanuc and Siemens for lathes?
    THANKS.
    Prash.
    [email protected]
    24221
    My personal favourites are Mitsubishi and Fagor, Fagor is the easier if you want to re-use the servo motor and/or drives.
    What have you used for the first machines you mention, I use a Galil card with a simple HMI program for the simpler machines, I am working on adapting the program for Lathes etc, but it is in the early stages yet.
    Al.
    Albert E.
    Jul 2007
    18
    technical info of Mitsubishi/Fagor
    THANKS. Can you tell me from where can I get technical information of these controllers?I have to use new motors and drives.I want to use proven and simpler controls because this is my first experience for lathe.Can you tell me what other things I need to know?The machines on which I work, use two
    AC -Servo axes and two hydraulic axes.In lathe I will need two servo and something for spindle.I have to study a lot. Please send me some links if you can.
    Prash.
    [email protected]
    24221
    It may be worth checking to see if there any CNC system suppliers located in India, this makes for easier support etc.
    Although it depends to some extent on your previous experience, (you appear to have had some in the retro-fit field).
    There is email support from practically all suppliers, ones like mitsubishi offer (or used to) free Ladder programming software and courses.
    Send out a few email 'feelers' to MEAU (mitsubishi) and Fagor etc, most of them, with the exception of Fanuc, have the manuals on line.
    An example with Mitsubishi, you give them details of the present system, existing motor sizes etc, they will supply a complete system, the requirement from you, apart from physically wiring into the machine, is to write the Machine control (ladder) and integrate the motors, i.e. scale the encoders and tune the motors, I have found Mitsubishi one of the easier ones, as they have basic parameters for the given motor size, They also use very close/similar format as Fanuc and others in the implementation of M,S & T codes as written into the ladder.
    If you have present axis in place that use +- analogue input, you may be able to use the existing motors/drives.
    Al.
    Albert E.
    Jul 2007
    18
    converting non-CNC lathe in to CNC
    There are so many suppliers in India;I have to define for which I have to go.And I don't know which are good for me.I have good experience in press breaks.Also I have 25 years of experience of electronic repairing(drives, linear scales, controllers etc.)This is the 1st time in lathe.From your reply it seems that I should check on the sites of Mitsubishi and Fagor.THANKS A LOT.
    Prash.
  1. Retrofitting with fanuc
    By IN-WondeR in forum Fanuc
    Last Post: 08-21-2007, 01:02 AM
  2. Retrofitting a control
    By carbidecraters in forum Fadal
    Last Post: 07-23-2007, 03:44 PM
  3. Retrofitting a Beaver NC5
    By IN-WondeR in forum Uncategorised MetalWorking Machines
    Last Post: 06-21-2007, 02:56 AM
  4. Retrofitting a Bridgeport
    By kuchean in forum Servo Motors / Drives
    Last Post: 07-24-2006, 07:46 PM
  5. Knee retrofitting
    By m_c in forum Knee Vertical Mills
    Last Post: 02-27-2006, 10:12 PM
