586,080 active members*
3,485 visitors online*
IndustryArena Forum > CAM Software > Uncategorised CAM Discussion > How to change the setup sheet format?
    Oct 2003
    14
    Hi
    Does anyone know how to change the setup sheet format from html version to text version?
    My surfcam version is 2002plus release build 49.
    I know there's a file named setupgen.cfg inside the surfcam folder, I've replaced it with the new setupgen.cfg (which by right should produce text format setup sheet), but when I restarted my surfcam and tried to create a new setup sheet, the old html format popped up again... That doesn't make much sense to me...
    Does anyone have any idea about that?
    Thanks...
    Oct 2003
    14
    Really no one knows about that?
    May 2003
    70
    You have to edit the surfcam.ini file to switch back to the old test format. I belive the info is in the help file. If I recall you have to edit the file manualy as it wasn't an option in the cfg tool at that time.
    Hope this helps
  1. DSTV file format?
    By ABC123 in forum Uncategorised CAM Discussion
    Last Post: 06-28-2013, 06:55 AM
  2. Having trouble cutting aluminum sheet
    By fastturbovet in forum MetalWork Discussion
    Last Post: 06-15-2005, 04:33 AM
  3. Mastercam Setup Sheet Help
    By stampman in forum Mastercam
    Last Post: 02-27-2005, 02:54 AM
  4. Turbo CNC Not Running.... Setup?
    By Davedbq in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-04-2005, 08:20 PM
  5. Taig CNC ready setup help??
    By efreak in forum Taig Mills / Lathes
    Last Post: 08-25-2004, 01:30 AM
