Looking for assistance on generating the code thru AS3000 by Camsoft.
My problem is producing the head raise or lower, plasma on or off when moving from one path to the next.
I had talked with a rep from Thermal Arc (Plasma machine supplier), who informed me of the actions needed for machine operation.
This plasma machine first requires the head to be near the material (M8 or O/P #24=1 Head down), then the plasma needs a contact closure (M5 or O/P #25=1 Plasma On), at this time the plasma will fire and once it senses a pierce thru it will provide a contact closure (I/P #22=1) at which time motion can begin. After completion of the cut, the plasma should be turned off (M6 or O/P #25=0) then the head should me raised (M9 or O/P #24=0). This process should repeat when the head has moved to the next object to be cut. After all objects have been cut the machine should
return to home position.
I wonder how and if I can use the Edit Process in AS3000 to accomplish this sequence. Also how does the system differentiate between a movement to a position before a cut begins from a movement where cutting should take place?
Any help would be appreciated.
Brett
