I am building mill to CNC, and I had an idea pop into my head. What if you encased the table in such a way that the entire table could be completely submerged constantly, with water coming up to .5" . 1.5" above the surface of the table? It wouldnt be pure water of course, but probably still something strait-forward like a bandsaw coolant or something (with a standard ratio of maybe 15:1). The X and Y motors would be mounted on the outside of the "bathtub" assembly, rather than on the table itself. The purpose of doing this would be of course cooling. I am building the mill in hopes that I can leave it alone for possibly hours at a time, and I thought it might be neat to literally just fill it up.
I really thought of this because I was thinking how messy it is to use coolant on my drill press, since by the time I get through a piece of .25" steel with a 2.5" hole saw, half my work bench is soaked. I also thought about how much higher and wider the tray on my bandsaw would have to be to really not lose any coolant (I have to add 8 cups of water every week or so of daily work, from it splashing out onto the floor). And in thinking of actually building a tray like that, I kindof wandered into this new territory of simply building it high enough that you could actually fill it with water and leave it.
The water would do a great job of cooling (think how long it would take to heat a bathtub full of water with a lighter...), but obviously wouldnt do much in the way of chip clearance.
So, do you guys think it would be worthwhile to try? The mill will travel 24"(x) x 6"(y), with a fully-supported table, so the box would likely be made so that it just butts up against the front of the column, rather than going around behind it, so the box would only have to be around 48"x12" (plus a few around the edges).
The alternative is building a somewhat more complicated tray of the same size, but with sloped bottoms so the coolant runs back to a smaller area to be picked up again.
*edit*
Other downsides include the water being pretty much useless if I have a vertically mounted rotary table mounted to the mill's table (like if I was milling lengthwise down a rod or tube), since it would be lifted off the table by a few inches. Another downside would be that it would have to be drained if I were to mount a rotary table on it horizontally, or else the motor would be submerged.
