586,105 active members*
3,248 visitors online*
    Hitachi seiki vs50
    Hitachi Seiki VS50 SEICOS E18M. When tool change start the x axis goes to twin arm and catches the tool and
    [2047] D404.7 LS Tool unclamp alarm followed by [2114] D411.4 ATC cam stop command LS detect error
    [2115] D411.5 ATC cam origin detect error
    [2185] D418.5 need ATC origin [maintenance mode]
    I've checked all the limit switches and sensor signals in PMC diagnostics. I couldn't come to a solution, kindly help.
    Mail : [email protected]
    Oct 2019
    17
    Re: Hitachi seiki vs50
    Without looking through the ladder, my first guess would be that the tool isn't unclamping and that is raising the rest of the alarm states. Will the tool manually unclamp?
    Quote Originally Posted by Hardplates View Post
    I've manually rotate the cam motor to check the cam condition, the twin rotates and unclamp cylinder and drawbar goes to unclamp state and moves back to clamp state as i rotate the cam motor.
    Quote Originally Posted by mathalaikanna View Post
    Now I've put the air bleeding procedure, M120 cycle functions and M121 cycle not functioning. I've Unclamped manually in selector switch, it's unclamping, when I try to clamp stops midway. I rotate the cam motor and positioned. Try again, same problem.
    Problem solved. ATC ARM motor inverter output cables loose contact.
  1. hitachi seiki VS50 pc card pcmcia problem
    By Rocket_Col in forum DNC Problems and Solutions
    Last Post: 11-07-2014, 04:03 AM
  2. hitachi vs50 problem
    By MoldMaster in forum Hitachi Seikis
    Last Post: 09-10-2014, 06:14 PM
  3. Hitachi Seiki VS50 / 16i-ma
    By peterson76 in forum Fanuc
    Last Post: 04-03-2014, 07:06 PM
  4. Hitachi Seiki VS50 Rotary axis
    By peterson76 in forum Hitachi Seikis
    Last Post: 03-27-2014, 11:30 AM
  5. Parameters VS50 hitachi seiki
    By Rocket_Col in forum Fanuc
    Last Post: 11-22-2011, 12:03 PM
