586,052 active members*
4,157 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > PlanetCNC > Save Points To STL and Measuring Outside Corners -> Built-into TNG?
Results 1 to 2 of 2
    Nov 2019
    41
    On Youtube I noticed two features demonstrated and cannot tell if these are readily available in TNG or whether they are something that I need custom G-Code and O code to perform. How do I do the following:
    1) Generating STL from probe measurements: https://www.youtube.com/watch?v=QRpyc9iHLls (CNCUSB)
    2) Measuring outside corner with probe: https://www.youtube.com/watch?v=jXMB9-SXTRg
    Thank you.
    Nov 2019
    41
    Re: Save Points To STL and Measuring Outside Corners -> Built-into TNG?
    What I have found so far to measure the points of a surface ("Save Points To STL").....
    In TNG with a probe configured, installed, and ready to measure...
    1) Machine -> Measure -> Surface
    2) Provide value.
    3) Once operation on step #2 is complete....Machine -> Points -> ___________
    3b) Notice at the top of the menu Machine -> Points, there is a heading "Count: " that is followed by the number of points measured.
    4) Choose to "Save ..." , "Save STL ..." , "Save DXF ..." , or "To Output" (the UI element) .
  1. Replies: 4
    Last Post: 11-09-2015, 02:37 PM
  2. Save .STL for Stock
    By jrmach in forum BobCad-Cam
    Last Post: 09-03-2014, 05:58 PM
  3. Save several neutral points
    By Juergen23 in forum HEIDENHAIN -> GENERIC
    Last Post: 08-07-2011, 05:33 PM
  4. Part to STL file save
    By SPEEDRE in forum Solidworks
    Last Post: 05-11-2011, 02:33 PM
  5. Save as *.stl
    By christodoulos77 in forum Mastercam
    Last Post: 03-27-2008, 02:54 PM
