586,114 active members*
3,330 visitors online*
    Jun 2010
    119
    C82 Board Axis Brake?
    I'm rebuilding my Milltronics Partner 1 mill with all new hybrid steppers, drivers, control, ect... I purchased a 24VDC brake to add onto my Z stepper. I'm trying to figure out how to wire it so that it is enabled with the control and will brake when e-stop is hit or the drive is disabled but I'm not seeing how best to do it. I have this system: https://www.automationtechnologiesin...-110vac-220vac .
    Thanks for any suggestions!
    Mike
    Jun 2010
    119
    Re: C82 Board Axis Brake?
    Found out all the outputs are disabled on E-Stop, so I think I'm good.
    Nov 2013
    4376
    I use the Motor0Enable signal to enable all my axes, up to six of them. It is active when the machine is enabled and inactive when the machine is disabled or Estopped.
    I use the same output to drive the electromagnetic brake circuit. When the output is active it turns on a Darlington transistor to pass approx 250mA through the electromagnetic brake
    on the Z axis servo.
    Craig
  1. DG4S-160, C82 BOB, Braking Circuit, USB Port
    By Floriptoolworks in forum For Sale Only
    Last Post: 08-31-2019, 01:13 PM
  2. Z axis has a brake - adding a limit switch to activate the brake
    By KipKirol in forum CNC Machine Related Electronics
    Last Post: 11-16-2017, 11:31 PM
  3. 600mm Box bend brake (Finger Brake, pan Brake)
    By RotarySMP in forum Bending, Forging, Extrusion...
    Last Post: 11-01-2015, 10:24 AM
  4. Parallel Relay Board & Z-motor brake issue
    By Liv2fish2 in forum DNC Problems and Solutions
    Last Post: 02-06-2006, 06:35 PM
  5. Opto Brake out board 4 axes
    By Chivo in forum CNC Machine Related Electronics
    Last Post: 09-15-2005, 02:05 AM
