586,094 active members*
3,989 visitors online*
Results 1 to 8 of 8
    Oct 2022
    39
    Parameter 1850 fanuc 18m
    Hi
    How to set the 1850 Fanuc parameter. ? In the rotary axis, how much is the change of this parameter equivalent to one degree?
    Dec 2009
    953
    Re: Parameter 1850 fanuc 18m
    look at the parameter 1821 that is the reference counter for the axis
    parameter 1821 divided by 360 degrees will be the value for 1 degree
    Oct 2022
    39
    The number of parameter 1821 is 2000 in my machine.
    When I divide by 360, it becomes 5.55556.
    That means it changes one degree for every 5.555556? Why is this not a rand number?
    On what basis is this parameter number 1821 selected?
    Thank you for your guidance
    Jan 2013
    474
    Quote Originally Posted by Electrify View Post
    Hi
    Out of curiosity, what is your rotary axis 1850 parameter currently?
    Oct 2022
    39
    I have 40 of this type of machine and the parameters are different numbers. There are from negative 12,000 to positive 15,000. My problem is that every time I enter random numbers to set the b axis so that the table is at the zero point on the index
    Jan 2013
    474
    Usually pwe=1 needs setting and e-stop depressed to change Fanuc parameters.
    Oct 2022
    39
    This is not my problem.
    I am familiar with the Fanuc system.
    I want to know the logic of setting the index table with parameter 1850?
    Dec 2009
    953
    do you know if you have abolute encoder or incremental?
    What do you have set on parameter 1815 for that axis?
    the value of the gridshift should be the same everytime you power on the machine after doing it first time
    that value is reset when you modify the APZ on the 1815 parameter
    so i think soething is not set corectly
