586,117 active members*
3,301 visitors online*
Page 1 of 2 12
Results 1 to 20 of 40
    Jan 2007
    39
    Solsylva 24" x 48" 1/2"-10 acme upgrade
    Hey Carve_one, Graham and all.....
    the solsylva acme upgrade is basically done, and producing parts!! Have run for a couple of days at X=60IPM and y=65IPM to check for loose parts etc.... Finally found all my strange intermittent problems where do to a weird issue with the puter I was running Mach with. Didn't realize that was the problem til I talked to Art.. The issues almost went away with the Acme upgrade, but were still there very intermitently. No probs at all since I changed out the computer.
    Now that it seems happy for a couple of days, I decided to see what it could actually do now. Just did a few air cuts of the contract job I'm doing, after bumping up the max speeds a lot. I set the Y up to ~100IPM, and the X up to 90IPM, accel at 10, and all jogs semmed happy, much to my surprise. It ran almost half way through the job before the Y coughed... WOW!!! set them both to 90 and it ran all the way through.. Gonna back off to 80 to actually run the job some more. Still a little gun shy after my weird problems...
    These are the following changes from the plans after a year of use....
    1) Xylotex board with 269oz steppers, 24" x 48" cutting area.
    2) NEW! 1/2-10 acme lead screws from Enco on all axis, no turned ends, using all 0.5" ID hardware, including bottom Z bearing added.
    3) NEW! Steppers on Y and Z coupled with short belts, not direct, with 15T pulleys.
    4) NEW! DumpsterCNC AntiBacklash nuts.
    5) NEW! Doubled up both of the 1x4 end plates to limit vibration, especially on stepper end.
    6) 1.5" x 2.5" Steel tubing for sides and gantry. (sure glad I did that, and to think I only used those because they were free LOL)
    7) Added dampers, since it really made the slower cutting speeds sound much better.
    Now to slowly change the rest of the wood to metal...
    Didn't go the multistart to keep upgrade price down. Didn't go ACME originally went 1/2-13 allthread, which was a disaster, since I didn't know about Enco 1/2"-10 prices, actually cheaper than allthread. LOL. I'm trying to forget the allthread trouble shooting time, cutting it out of my life.....
    All that said, Does anybody out there have an extra foot of 1/2"-10 5 start, or 1/2"-8 4 start they didn't use from a longer piece? want to change the 1/2-10 on the Z axis to this to help with the moving the weight up and down issue. Some contract stuff I'm cutting has about 605 up and downs in each cut, and the Z is the weak link from a speed standpoint right now with the 1/2-10 single start.
    Or else does any know anywhere on the web that will sell a 12" piece? everywhere seems to have a $50-$60 minimum order, and I only need 12", about $9 worth...
    More on the upgrade and some pics maybe tomorrow, and will upload the gcode for part of the contract job, since it is a VERY good test of the machine. 55 sets of 11 holes, 605 in all, on a 2'x4' sheet of luan..
    Don
    www.eurekaaircraft.com
    Nov 2003
    452
    Im building a machine very similar to yours. Same screws, but 400 oz in motors w/xylotex controller. 4' x 6' table
    i counted on problems with moving z axis up & down, my question to you is how do you expect to move the z axis with multiple start screw? Faster?? Don't the step motors have enough trouble just moving all that weight?
    My plan's to use 400oz in steppers on the z axis with 1/2-10 screws. Would you suggest sticking to this plan?
    Apr 2005
    81
    Try Widgetmasters ebay site I know he has 6" to 18" acme screws. Go to
    www.widgetmaster.com and click on his Ebay link.
    Vince
    Jan 2007
    39
    Justcncit....
    Going to a lower pitch thread gets more movement per rev of the stepper, so more speed will be achieved since you will get more speed at the rev that works now, ie at the same torque point of the stepper. Same reason you get more speed from 1/2-10 than you do from 5/16-18. Steppers lose torque as the speed up, so you try to get more movement at the same RPM. The stepper doesn'y know you changed the lead screw. And yes before anybody screams, it won't be the theoretical increase of 5x the speed, going from 10TPI to 2 TPI, due to intrinsic losses, but it should get me to where I want to be. I don't know if I explained this right, but the jist is right. Talked to David Steele, he has tried it with 3/8"-10 2 start, and it definitely helped. Time will tell.
    I though about making some kind of counter-weight, similar to the way they do the harbor freight/grizzly mill upgrades, but the Y axis moving opens up a real can of worms doing that, plus the space issue.
    Don
    Jan 2007
    39
    vconney, tried the link and there isn't a page there now. Do you have any links to his ebay stuff, or his exact ebay name?? thanks
    Feb 2004
    1086
    rc_flyer,
    I have an extra 3' length of 1/2-10 5 start. It's slightly bent, which is why it's extra. However, I'm guessing there's probably a foot of it that's straight. I'd be happy to send it to you for free so long as you pay shipping. I'm in a good mood since I got my machine moving tonight .
    Oh, and on the subject of getting higher speeds -- higher pitch ACME has significantly better efficiency (sometimes up to 70%, compared to only 20%) than single start 1/2-10. This means that you basically get your extra speed for free! Well, not quite -- you're still trading off resolution. You're also right in saying that it's good because it keeps the stepper turning slower, where it has more torque. Case in point, with the same motors, I went from 200 IPM on single start to 700 IPM (!) on 5 start.
    Anyway, PM me your address or send me a note through my website and I'll hook you up with the ACME rod.
    Ahren
    www.cncrouterparts.com
    Jan 2007
    39
    First part pictures...
    Here are pictures of the lead nut mounts. They mount to 1" alum angle that replaces the 3/4" used with the smaller rod, to give room for the 1/2" rod. No pictures of those before mounting , but they are simply wider versions of the original, same holes and slots. Same mounting procedure. I tried to keep this simple, just slightly bigger.
    The DumpsterCNC AntiBacklash nuts are used through out. They are very high quality pieces. I ordered the round flanges since I wasn't sure how to mount them till they arrived.
    The mounts are made from 2" angle, about an inch wide, so they would be long enough for the screws to reach both slots, as before. The holes are 5/8". One end is cut down to match the shape of the AB nuts flange, as shown. The AB nuts flange is sanded to fit the mounts after mounting them. I used 8-32 bolts, with holes in the mounts tapped. The holes for the adjustment bolts are tapped in the mounts as before. All adjustments are as before.
    The Z mount is trimmed down much further to get it to fit in the very tight space. It is barely wider than the barrel of the nut. I moved the Z axis trucks out closer to the edge of the box to get more room behind.
    Other info: I used .5" ID- 1.125" OD bearings, (R8ZZ from Ebay) so new bearing mounts had to be made. I also used .5" ID pulleys from SDP and ordered Acme nuts from Enco along with the rods, so no turning of ends was needed. The new rods fit the bearings perfectly, unlike the old allthread, so no clicking.
    Pics of the Y and Z stepper belt mounts, the new bearings in place, and other mods to come, as I get a chance to put them up.
    If you want to see anything in particular, just let me know.
    Don
    Attached Thumbnails Attached Thumbnails new AB nut from dumpsterCNC installed on Y axis.jpg   this is how AB nut mounts on new mount.jpg   two X axis AB nut mounts with 5-8 inch hole another view.jpg   z-axis lead nut mount-1.jpg
    Apr 2007
    8082
    Don,
    Your upgrades are looking really good. Thanks for sharing the information and I'll follow your lead as cash is available.
    CarveOne
    CarveOne
    http://www.carveonecncwoodcraft.com
    Nov 2003
    452
    I think alot of people are following this lead. Alot of people are using .5" shafting & dumpsters nuts. The only thing yet to catch on is Ahren's bearing blocks.
    Apr 2007
    8082
    justCNCit,
    this is not intended to be a rant, but more of an explanation as to why I didn't buy them myself.
    I looked at Ahren's site a while back and determined that the bearing blocks shown there are fine for the builders who don't have a mill or where a standardized block shape will work ok, as with the 8020 extrusion machines. The price is very reasonable for the amount of work involved in making them. I didn't see any note that Ahren will make custom shaped blocks for other machine designs.
    Had there been a set available for the plans I'm building from then it would have added more than $100 plus shipping to my build cost. My bearing blocks need to be differently shaped, and I can mill them myself from the aluminum stock I already have on hand, so I didn't order them. I think that any low sales is not a quality or design issue as much as there will be a more limited market by not having available a small selection of kits for the more popular machine designs in addition to a standardardized bearing block for 8020 machines.
    CarveOne
    CarveOne
    Feb 2004
    1086
    Hi guys,
    I'd be interested to know if there are other "standard" designs for bearing blocks or motor mounts you all would be interested in. I made a run of the ones I have because they worked so well for my machine, but I realize they won't work for everyone. The setup time for custom blocks makes the pricing somewhat prohibitive, but I'm open to changing the design to make it more universally appealing.
    I'm planning on releasing plans at some point for a complete 8020 machine, but I have a few details left to work out on the linear motion system (trying to keep costs down). Anyway, I don't want to hijack this thread, so feel free to PM me with ideas that you'd like to see become metal.
    Jan 2007
    39
    more pictures.
    Here are some more pictures of the upgrade. Instead of going into a long explaination of each picture, just ask for details on any pic.
    Don
    Attached Thumbnails Attached Thumbnails y bearing dual nut end.jpg   y bearing dual nut end -2.jpg   X  AB nut showing spacer for mount.jpg   X  AB nut showing spacer for mount - 2.jpg
    Jan 2007
    39
    Pictures of upgrade page #2
    Here are some more pictures of the upgrade page # 2. Instead of going into a long explaination of each picture, just ask for details on any pic.
    Don
    Attached Thumbnails Attached Thumbnails y bearing and pulleys for short belt.jpg   y motor mount end view for short belt.jpg   X stepper mount view - 1.jpg   X stepper mount view - 2.jpg
    Z stepper modified mount top view.jpg   Z stepper with extra bearing sideview.jpg
    Apr 2007
    8082
    Wow!! Don, did you really carve that -very- realistic looking cat?? The precision is just amazing. Details please....
    How are the x axis acme rods running now? Any whipping problems? Are they running straight and is the belt tension on the pulleys causing any bowing of the rods?
    CarveOne
    CarveOne
    Jan 2007
    39
    yeah, he is the only thing that seems to get bigger the more I cut...LOL
    The first thing I noticed, even with the 1/2" allthread from hell, is that the 2 bearings on each end of the X had a much more drastic effect on controlling the whip. They never seemed to help a lot on the thinner rod. There is very little whip on the x leadscrews at all any more. It varies slightly at different higher rpm's, like of a resonance thing. At most speeds it completely dissapears, and gets just a little at some random speeds, less than a 1/16" deviation at worst. Any whip that is there doesn't seem to effect top speed at all. With over 5' of rod, it will never go away completely.
    I have the X belt tighter than I ever could have it with the smaller rods. There doesn't appear to be any bending cause by it. I think as I do more fine adjustments, the speed will continue to incease a bit.
    The main thing I have noticed is that since the rods fit the bearings perfect now, it is critical that they are at exacly 90 degrees to the rod. There was a slight margin for error with the smaller, loose fitting rods.
    Don
    Apr 2007
    8082
    When you are cutting some 1/4" birch plywood, and making 90 degree turns (or less) please check the x axis rods to see if they tend to take a momentary hit as the router bit rapidly changes direction. Hopefully, the long belt minimizes any jolts to the rods other than disastrous slams into the stops.
    Which brings up the point of limit switches and zero reference switches. Do you have any installed on your machine?
    I would like to see a photo of a sample 1/4" birch plywood wing rib if you don't mind, as we use them in our heavy lifting RPV models. These things have been stress tested at ~70 lbs lift off weight. My cnc router is being built to cut these 20" chord wing parts and other fuselage parts. The root ribs are close to that length in some of your kits. I would like to show the picture to my boss for cut quality purposes.
    CarveOne
    CarveOne
    Jan 2007
    39
    Carve..
    I guess I don't understand your question. When Mach is operating in constant velocity mode, which is how I always run it, the motors don't come to a screeching halt, then change directions. They do what I guess you wound call 'pivot' around the corners, making a rounded path, but it leaves the point just that, a sharp point. It does some kind of look ahead. I don't know how it does it, but the cutter never slams around inside or outside corners. Maybe someone with more experience can explain why that isn't a problem. (or Art is just a freaking progamming god, and it has to do with Karma
    If that isn't what you are talking about, email me with a better explanation of the question, I'll see if I can figure it out...
    As far as limit switches, I have 3 limit/home switches doing double duty at X & Y zero, and Z top. I don't have them at the other extremes, and have never regretted it so far. I'm sure they will get there eventually. At the 0 extremes, I want them in case the machine does lose steps, on the way back it could go past 0, thinking it is only going to 0. I have had that happen before, in the past, although it has been a while. I don't see it happening going the other way, since I don't think I have ever run a program that goes that close to the ends..
    Don
    Apr 2007
    8082
    Thanks Don,
    You answered my question well enough.
    I haven't seen one of these Solsylva machines running in person, but I was told by a local hobbyist cnc laser cutter builder that this would be a problem with the 1/2" acme rods same as with the smaller rods. I was skeptical of this statement and wanted to know if you had seen this. Watching ShopBot and other videos on YouTube sure didn't show anything like this but they use rack and pinion drives.
    CarveOne
    CarveOne
    Jan 2007
    39
    Hey Carve.. Hope the pictures I sent helped.
    I guess I don't know where he's coming from. I would be very skeptical. I have never noticed that on either size rod. I don't think it will matter which you have, rack, ball, lead screw... A sudden change in direction will jerk and shake the table if not controlled. It's called inertia, and no control system in itself or table design will change that, without effecting accuracy. I would venture to guess that is why the CV mode is in Mach, and probably most other software, so the software can plan ahead and control velocities as needed, to help limit the problems caused by inertia.
    I wonder what sofware he runs the laser with, and if they don't have the Constant Velocity mode. Maybe you should turn him on to Mach, I think it has special controls for the laser.
    Don
    Apr 2005
    81
    Hey RCflyer,
    I misspelled the link...this is the right one.
    http://widgitmaster.com/
Page 1 of 2 12
  1. "low end" HF Spindle or "high end" router for about $1000?
    By biomed_eng in forum DIY CNC Router Table Machines
    Last Post: 01-06-2012, 07:15 AM
  2. BattleAxe "aka" Ball and Chain "aka" the wife.
    By ZipSnipe in forum Community Club House
    Last Post: 05-18-2008, 03:53 PM
  3. Has anyone looked at the "JET" or "Shop Fox" manual machines?
    By boosted in forum Uncategorised MetalWorking Machines
    Last Post: 03-05-2007, 04:33 AM
  4. Vertical system "jerks" and "bangs"??
    By REVCAM_Bob in forum Servo Motors / Drives
    Last Post: 06-12-2006, 03:09 PM
