586,117 active members*
3,444 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > thk actuators vs thk lead/ball screws
Results 1 to 8 of 8
    Aug 2007
    57
    hello cnczone
    i have a question sorry if my terms are rough ! im now buying the needed parts to build my cnc mill . i have picked up a thk linear actuator for my z axis , along with thk lm slide rails . im having a hard time finding thk actuators with the stroke lenghts i need 24"and 30" or something close.
    i will be using thk lm slide rails for all axis . do i really need actuators or will just the lead/ball screws do fine .the reason i was leaning towards the thk acutuators was for the ease of install .
    sorry if the above doesnt make sense its late .
    thanks for any info
    cheers
    mike
    May 2007
    6
    THK KR33 based CNC Mill
    I made my cnc mill using THK KR33 LM series, very easy to mount and though second hand actuator but backlash should be less than 10 micron. I only have a 10 micron resolution dial gauge.
    Definelty worth it not only easy of mounting but also for straightness and stiffness.
    Sep 2006
    11
    Smile cnc mill
    Thats a great machine,I want to know where to buy the male and female dovetail slide components. The salvage from metal lathes are expensive and generally do not have enough length. Thks,pw
    May 2007
    6
    Homemade CNC Mill
    I got the complete THK KR33 module from a scarp dealer in my country, Singapore. Mine is about 450mm stroke with a 6mm pitch. There is no dovetail component. They are based on THK caged bearing system. The scarp dealer has lots of different length available. Let me know of your requirement and I might be able to help.
    Apr 2004
    5737
    Building a machine based on actuators vs from scratch
    [QUOTE=mjs79;346192]hello cnczone
    thanks for any info
    cheers
    mike
    [You don't need to use actuators, but I found they make things easier. It's possible to mount ballscrews, bearings, motors, and slides accurately on a straight, stiff piece of metal, and build a platform that slides on them to attach to, but if you get an actuator that's all done for you. I built a machine from similar units myself; I posted something about it in the DIY router section (Deep Z 4-axis machine - no replies yet). I might have some more NSK actuators that would work for you; let me know what lengths you need. Mine have Tamagawa servo motors and steep-pitch screws, but they can be driven with stepper motors if you make adapter plates for them.]
    Andrew Werby
    www.computersculpture.com
    Aug 2007
    57
    im looking for actuators with a travel of 24" and another with 30" of travel/stroke .if you have anything please let me know .
    thanks for all the info you all have helped me alot .
    cheers
    mike
    May 2007
    6
    CNC Mill
    Hi Mike,
    The scrap dealer do have THK KR33 actuator near to your requirement of 24" and 30", but they are not new actuator. Each is about USD$450 not inclusive of shippment yet.
    Aug 2007
    57
    thanks for the info . you have PM ^^^^^^^^^^^^
  1. Ball screw or Acme lead screws
    By bgolash in forum Polls
    Last Post: 12-26-2020, 12:00 AM
  2. Where to buy lead screws?
    By eldruida in forum Linear and Rotary Motion
    Last Post: 09-24-2007, 12:33 PM
  3. 1 or 2 lead screws
    By spoolin_20b in forum DIY CNC Router Table Machines
    Last Post: 03-22-2007, 10:50 PM
  4. Ball screws, Acme screws, threaded rod
    By DJ Morrow in forum DIY CNC Router Table Machines
    Last Post: 03-22-2007, 06:39 PM
  5. CNC Router (Ball Sliders and Lead Screws)
    By JB Laser Tech in forum Linear and Rotary Motion
    Last Post: 12-04-2006, 12:45 AM
