586,117 active members*
3,444 visitors online*
    Sep 2014
    China newker 1000 series servo gear ratio
    Hi there
    As seen in the photos, when I say go 1 mm, when it goes forward, it goes missing. How is the belt system calculation done? I did not fully understand the handbook you gave.
    my Y axis
    When 3mm goes, the bench goes 2.91mm.
    When 2mm goes, the bench goes 1.92mm.
    When 0.3mm goes, the bench goes 0.26mm.
    My gear system:
    Servo shaft: 24 tooth
    ball screw input : 49 tooth
    Ball screw pitch: 5 mm (1 turn)
    Please check my gear parameter 1.jpg picture for y axis.I think,its is a wrong
    I think my settings are wrong, can you calculate for me?
    I am waiting for your reply.
    Attached Thumbnails Attached Thumbnails 0,30mm.jpg   2mm.jpg   3mm.jpg   gearparameter1.jpg
    Mar 2015
    410
    Re: China newker 1000 series servo gear ratio
    After the first move to -0.3 mm, the change in position equals the change in move. So the settings are OK.
    You have backlash/play/tilt in your Z-axis resulting in about 0.08 mm backlash. Check the play in your guides, spindle nut, spindle bearing, flexible coupler, belt elasticity, belt / pulley mismatch. Even the indicator could suffer from backlash.
    Mount a bolt on the large pulley, mount an indicator (magnetic holder) on the frame and move the pulley CW. zero the dial (ref position), move the pulley ccw a small step and thancw back to the reference position. It should be zero again. Repeat the procedure but now rotating the pully not a small step, but half a turn. It should be 0 again.
    Repeat the steps above but now in the opposite direction. I guess, you will find the source of most of you problems.
  1. I need help with gear ratio.
    By modelaratrod in forum CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 11-14-2016, 03:20 PM
  2. How to get a 705:1 gear ratio
    By intel2you in forum Mechanical Calculations/Engineering Design
    Last Post: 04-12-2012, 03:22 AM
  3. What is the BACK GEAR RATIO for Bridgeport Series II Interact 2?
    By ichudov in forum Bridgeport / Hardinge Mills
    Last Post: 12-29-2010, 08:04 PM
  4. which gear ratio
    By sempar in forum Linear and Rotary Motion
    Last Post: 07-24-2007, 09:55 PM
  5. gear ratio help
    By Erick Davidson in forum Waterjet General Topics
    Last Post: 05-30-2006, 04:04 PM
