586,110 active members*
3,343 visitors online*
IndustryArena Forum > CAM Software > Uncategorised CAM Discussion > Help on Emmegi Diamant Equipment Using Camplus
Results 1 to 19 of 19
    May 2007
    4
    I am looking for someone, anyone who has experience with Emmegi equipment. Emmegi is Italian made equipment using propietary software, Camplus software. My experience has been with Solidworks/Camworks on Mazak equipment. If anyone is familiar with Emmegi or Camplus or knows of a third party software that can be used instead of Camplus with Emmegi, I would be very interested in talking with them. Camplus seems to be pretty straight forward in itself, looks can be deceiving, but you have to use about 4 different software packages, Camplus, Drill, Cam, Job to set up a production run. It seems there should be a quicker, easier and more straight forward way of doing this. We are not machine complicated features here, they are holes and slots.
    Thanks in advance,
    Scott
    Dec 2008
    A little late but....
    I have used knowledge using CAMPlus, we have two Phantomatic T4. I would be interested in talking to you about issues you have ran into with these machines.
    May 2010
    Camplus Software on Diamant Emmegi machine
    Hello,
    I am using Camplus Software on our Diamant 4 axis machine. I only been using this for about 3 months. We an Aluminum Factory in Dammam, Saudi Arabia. So we are using this machine to makes holes, slots, notches(with Saw Blade) for Windows and Doors of all types. We have around 50 different profile configurations.
    I am designing with Camplus, if you have different sizes, etc.. you may enter into Job software and then send it to the Drill software(the machine itself).
    Yes, the setup can be sometimes a little challenging, but once it is setup and tested, the machine is great.
    Although i do not like manually adjusting the clamps or vices for different profiles.
    Regards,
    Gary Joyner
    Apr 2008
    hi there,
    we recently bought this machine T3 star for basically machining aluminum extrusions, our part profiles are little complicated with cutouts on the ends and radiuses.
    like someone else mentioned in on of the threads that there are ways to get around but I still find a lot limitations within the interface.
    since we are new to this software I am running into some basic issues while programming so basically I am looking for guidance.
    the support from Emmegi is not that super or very efficient.
    if anyone can help me here plz reply to this thread.
    thanks
    Apr 2019
    I am a current operator and programmer for a emmegi t4 comet. I used this cnc mill to produce aluminum extensions of many different shapes and sizes daily for us in the production of trucks bodies and grain trailers. If anyone needs help with programming and or operating issues feel free to ask and I will help as best I can to answer all your questions. These machine are and can be tricky to say the least to setup however once the initial and proper set up is complete all runs are possible there after.
    Aug 2019
    Hello, I am wondering if you help me understand how to set the clamp positions on an Emmegi Phantomatic T5
    Quote Originally Posted by npv08 View Post
    Aug 2019
    Any help on how to set clamp position on an Emmegi phantom t5 in the drill program? Would be greatly appreciated
    Dec 2019
    Re: Help on Emmegi Diamant Equipment Using Camplus
    Hello to everybody. Can someone help me about my X4 phantomatic?
    Apr 2021
    Hello. Do you also have experience with the operation of CAMplusCNC ver. 4.2 / 3? I accidentally clicked away a control panel and can no longer activate it. If you have loaded a file, the profile is displayed and to the left of it was a display with the already saved edits. That ad is gone now and I can't find where to show it anymore. Thank you for your help.
    Apr 2021
    4
    EMMEGI - MICROMATIC STAR - 2011- 5 axis- worked max 100-300 hours- including CAMplus software- X/Y/Z=370/130/140 mm (longitudinal / cross / vertical)- A axis (automatic wrkpiece relation) -180 degree - +90 degree- U axis (bar positioning) 1020 mm- spindle taper ISO 30- max spindle RPM 11500- main motor 1,1 kW- ATC 6- max tool size: d10, L=100 mm- max workpiece size machinable from 4 sides: 120x100x2800 mm- standard number of vices 4+2
    Bi78uwrh9u
    Mar 2020
    Hey do you find any way to "empty" a shape as you can empty a rectangle or a hole or slot
    I have a complex form to be cut out in aluminium.
    Now we have to draw every line in dxf .
    If ou have a easier solution please could you share ??
    Mar 2016
    Hi npv08. We run a comet T4 5 axis machine and interested to know if you calibrate your own machine (C and B Axis in particular) We have 3 x Satellite machines as well that we can calibrate axis on however the machine supplier wont provide the password for us to complete in the Comet T4. We have been able to do this via the axis drives without the password but it is not ideal.
    Can anyone help me out on this?
    i've been using the emmegi phantomatic t5 for about a year and a half now.the dxf files are limited to just 4 profiles because the other dxf profiles that we install cannot be read by the computer. so, i had to adjust holes,notchings and blade dimensions especially on the z axis.
    it's a little complicated but we can mill all the job orders that come to us,except for pieces that have short lenghts.
    Dec 2006
    39
    I have a vast amount of experience with and Emmegi Satellite XL and programming using CAMPlus.
    Unless you purchased the G-code (or ISO as they refer to it) code option you are stuck using their software.
    You only need to program in CAMPlus, then export to LDA which is opened directly in Drill loaded on the machine. Job is not needed unless you are grouping a bunch of programs to be cut from bar.
    EDIT TO ADD: Oops, didn't realize at first this is a 6 year old post.
    Hi sir
    Hi sir ...how are u
    now i am working wmmegi xl satellite
    my knowledge is goood
    but i have a big proplem (making arcs)
    how can i ake an any arc
    can u give me example
    what are the data can give u the custumer for arc
    and how can u make it on camplus
    and i have other q
    how can i make and difficult shapes like stars or any closed shape
    any help will be so apperciated
    can u text me to my mail
    [email protected]
    thank u
    murad
    hi mr G
    plz
    can i contact u
    this is my mail
    [email protected]
    hi mr g
    please help us
    i think u are so profetional
    i want a way
    to see my work on the peice on computer before real working
    plz help me
    Hi Mr G....plz
    can i contact u ?
    i need u so necessary
  1. Camplus on Emmegi
    By Session in forum Uncategorised CAM Discussion
    Last Post: 02-14-2024, 12:15 PM
  2. Emmegi CNC Equipment Question
    By scott4tg in forum Uncategorised MetalWorking Machines
    Last Post: 08-18-2015, 07:50 AM
  3. Any one 4 help ..plz ...emmegi cnc
    By Muradrabaia in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 12-07-2013, 06:28 PM
  4. Help CNC / Diamant tools
    By emptystr in forum Glass, Plastic and Stone
    Last Post: 12-07-2011, 08:21 PM
  5. USED CNC EQUIPMENT
    By ptd in forum News Announcements
    Last Post: 09-16-2011, 04:20 PM
