586,061 active members*
4,673 visitors online*
    Sep 2007
    Question port and pin settings not saved?
    I am a newbi to the scene an making my experiences with Mach3 R2.41 trial version. I have two problems that I would like to describe.
    First of all I am testing the pin port settings and got so far that the driver engine gets signals (I can see that because I got a physical LED testing machine) the LED are working (on or flashing depending of what I do) also the engine gets an impulse I can feel that- only it does not move!!!
    As if the were no repetitve stepping signals... can someone answer this question?
    The second quesstion is more easy to imagine. All the settings in the pin and port adjustments go constantly lost when I close the program even if i click save settings in the config tab afterwards. Anybody knows and solved this problem???
    Thx
    Quote Originally Posted by Block16 View Post
    Thx
    Make sure your Mach3mill.xml is not set to read only.
    Sep 2007
    Smile
    Thank u I m checking this
  1. NcPlot could have saved my butt
    By Karl_T in forum NCPlot G-Code editor / backplotter
    Last Post: 08-30-2006, 12:51 AM
  2. MACH 1.90.065 "Nedd port and pin settings
    By over60 in forum Mach Mill
    Last Post: 08-08-2006, 01:32 AM
  3. parallel port settings/output signals
    By TMaster in forum Xylotex
    Last Post: 04-24-2006, 05:16 AM
  4. dnc settings
    By jamesr in forum Fanuc
    Last Post: 02-02-2006, 09:13 PM
  5. Mach 2 and settings
    By tauscnc in forum Commercial CNC Wood Routers
    Last Post: 05-25-2005, 03:05 PM
