586,058 active members*
4,522 visitors online*
    Oct 2010
    5
    GrblGru Troubleshooting
    Hi there. I installed Grblgru. I have connected arduino mega with ramps and i get to following error. I didn't edit in any way the config file by the way.
    Please help.
    May 2016
    333
    Re: GrblGru Troubleshooting
    Can you please give us more details about the error.
    What error message is displayed ?
    Which Mega-5X version and which GrblGru version are you using ?
    When exactly does the error occur ?
    Oct 2010
    5
    First it gives me a pop up window error message that says:
    >G10 L20 p1 x0 y0 z0 a0 b0<
    Grbl error:9
    G-code lockedd out during alarm or job state.
    See controller windows for details
    GCode transmition is aborted
    And then in the controller window below it shows the following
    grbl 1.2h ['$' f
    ok
    ok
    [MSG:Caution: Unlocked]
    ok
    Grbl 1.2h ['$' for help]
    [MSG:Check Limits]
    [MSG:'$H'|'$X' to unlock]
    I am using this Mega-5x version
    https://github.com/fra589/grbl-Mega-5X
    The GrblBru V5.0.10
    Nothing occurs
    Thank you for your reply
    May 2016
    333
    It looks like you are using a Mega-5X version that does not support all of your axes.
    When installing GrblGru, in the directory Program(x86)\toe\GrblGru xxx
    the file 'grbl-Mega-5X-v1.2d_XYZAB_SPINDLE_PWM_ON_D6.hex' is
    stored.
    Use the program 'XLoader' to flash your Mega-5X controller with this file.
    This provides the axes X, Y, Z, A and B.
