586,089 active members*
3,800 visitors online*
    Sep 2007
    16
    DNC for new Mazatrol
    New Mazatrol controller does not have serial port. Instead of this a USB port is available. Manual says this USB can be converted to serial. Any idea how to do this?
    Feb 2006
    992
    Radio Shack.... well for an adapter.
    The best way to learn is trial error.
    Jul 2007
    284
    Talk to Mazak. They have the USB to Serial adapter and a procedure on how to do it. Do not just buy any adapter. Not all of them will work and you may go through a couple before you get one that works. Your just best off contacting Mazak and getting a known working adapter as well as the procedure.
    Mar 2005
    988
    Why not just use the USB? Just use a memory stick. Or hook up the ethernet...
    It's just a part..... cutter still goes round and round....
    Sep 2007
    16
    I still need serial port. I have connected this machine with a wireless tracking system and it needs a serial port.
  1. Mazak M-4 Mazatrol T2 and mazatrol Cam T2 operating manual in english
    By tuanpq in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-09-2021, 04:06 PM
  2. Mazatrol CAM T4 parameters
    By active-precision in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 09-05-2008, 07:19 PM
  3. mazatrol T1 Qt 20
    By nastek in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 02-16-2007, 02:46 PM
  4. Mazatrol MT Pro
    By wawankot in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 08-12-2006, 05:01 AM
  5. does m-cam do mazatrol?
    By underdog in forum Mastercam
    Last Post: 10-12-2005, 03:30 AM
