586,096 active members*
3,713 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fagor Automation > Circular interpolation Fagor 8050, 8060 ...
    Jan 2023
    Hello
    First of all, since this is my first post, I would like to thank all of you who make this forum possible.
    Although I have programming knowledge in other areas, I have recently started to learn CNC programming and I have been reading this forum which contains a lot of interesting information.
    Today I would like to create a new post to try to solve a doubt about the circular interpolation in the Fagor 8050, 8060, 8070 controllers... that probably is simple but I have not been able to solve (The tests have been done on the Fagor 8070 lathe simulator):
    To perform a circular interpolation there are two ways in which it can be done, indicating the end point and radius or with incremental coordinates using i, j, k.
    In the first way it works perfectly, for example:
    G00 X40 Z60
    G18 G03 X90 X90 Z110 R50;
    However using incremental coordinates:
    G00 X40 Z60
    G18 G03 X90 Z110 I50 K0
    I get error : 1028 'The difference between the programmed center and the calculated one is too large'.
    But according to the documentation I think the command would be correct. Has anyone had a similar problem?
    Thanks to everyone for your comments
    Jan 2023
    Re: Circular interpolation Fagor 8050, 8060 ...
    I answer myself, I have been able to locate the problem, you have to take into consideration the type of coordinates you are working with.
  1. Fagor Bodor 8060 Tube Cutting Machine
    By ats6 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-04-2022, 12:42 AM
  2. fagor 8060-8065 control
    By Darijo in forum Fagor Automation
    Last Post: 08-04-2017, 03:19 PM
  3. Fagor 8060
    By MarcoGaspar in forum Fagor Automation
    Last Post: 07-13-2014, 03:31 PM
  4. Fagor 8050 M need help
    By Nadrik in forum Fagor Automation
    Last Post: 10-03-2012, 09:03 PM
