586,075 active members*
4,143 visitors online*
    Jan 2013
    73
    Sinumerik 810M stuck on initializing screen.
    Good day, my sinumerik 810M GA3 is stuck on initializing screen. Im guessing it is hardware problem.
    Is it normal for red LED on the back of the CPU card to be lit?
    Could it be the bad EPROM or interface card?
    The problem started with empty battery and parameters deleted.
    I left the machine running to upload the parameters later.
    I went to another machine (Mazak CNC lathe) and turned it ON and this one takes a lot of power when its turned on (the lights go dim for a second) and the other machine dont like that.
    When I got back to my miling machine 810M now there was
    QVZ error on the screen. (Photo in the attachment)
    I couldnt get this screen off, so I took out the battery.
    After that I am stuck on initializing screen.
    I tried to remove EPROM and get the EPROM error
    (On the photo attached)
    I tried to remove interface card and I get the interface error
    Thank you for your help.
    Attached Thumbnails Attached Thumbnails download (12).jpg   download (13).jpg   download (11).jpg
    Re: Sinumerik 810M stuck on initializing screen.
    Replace this with a PC based controller.
    Open a ticket and send pics of the electrical components and we will send you recommendations:
    https://www.cnc4pc.com/contact
    Jan 2013
    474
    Quote Originally Posted by mlinkadelsol View Post
    The parity monitoring error would indicate data corruption. Perhaps try deleting the memory and uploading a clean copy of the system parameters.
    However, I guess the control could have a damaged card or EPROM.
    Jan 2013
    73
    Quote Originally Posted by servtech View Post
    Hy, thank you very much for your support.
    I cant get past the initializing screen, and dont know how could I delete the memory because "eyeball button" doesnt work either.
    Do you own by any chance sinumerk 810? And can you check if your LED on back of the CPU board is ON?
    Jan 2013
    73
    Quote Originally Posted by arturod View Post
    Hy, thank you for your input.
    The system is old and analog and currently I have to get it up and running as soon as possible because of the deadlines.
  1. Sinumerik 810M
    By AM7 in forum SIEMENS -> Sinumerik 810M/810T
    Last Post: 10-19-2017, 11:13 PM
  2. Sinumerik 810M CRT replacement with Computer Screen
    By globalrobotics in forum CNC Machine Related Electronics
    Last Post: 02-07-2014, 07:54 AM
  3. SINUMERIK 810M GA1
    By amo in forum CNC Machine Related Electronics
    Last Post: 11-17-2009, 09:58 AM
  4. Sinumerik 810M
    By desperado2000 in forum SIEMENS -> Sinumerik 810M/810T
    Last Post: 06-30-2008, 09:38 PM
  5. sinumerik 810m
    By knightstep in forum SIEMENS -> Sinumerik 810M/810T
    Last Post: 09-09-2006, 02:45 PM
