587,006 active members*
2,986 visitors online*
IndustryArena Forum > Tools / Tooling Technology > CNC Tooling > Internal thread cutting tools
    Apr 2011
    131
    I'm looking for suggestions on internal and external thread cutting tools that would work well with my lathes ATC. I'm starting with nothing.
    I can figure out the external (though suggestions still welcomed) but I'm not sure what are good options for the internal.
    As a first thread cutting project I want to make a 5/8-18 female to 9/16-18 female coupler out of 3/4" brass hex stock (internal threading). My tap kit doesn't have these sizes. I'd also like to be able to thread other smaller sized holes that I don't have taps for (rather than buying taps). I'd like to get a good set as I dislike starting a project and finding I don't have the right tool and having to wait .....
    More info:
    Lathe is an Intelitek Prolight 3000. It has the factory tool changer (see images below).
    There are four 1/2" round mounts for boring bars, drills and internal cutters. The lathe came with a couple of 1/2" Criterion stubby boring bars (7250B and 7375B) but nothing to cut threads.
    A set of stubby indexable internal cutters which are all 1/2" mount but a variety of hole diameters would be ideal but I'm not sure this exists.
    I'm seeing the SEL/SER indexable cutting tools and also "small diameter" internal cutting like the following:
    https://www.aliexpress.us/item/2255799974812840.html
    https://www.aliexpress.us/item/3256804427921570.html
    Long I can see maybe being useful for deeper holes but since I can't set the tool back in my changer I'm concerned about deflection for most projects so I'd probably have to shorten. Also for anything with a mounting OD less than 1/2" I'd presumably have to machine a sleeve to fit the changer?
    For budgetary reasons I'm probably looking at Chinese made tooling (or good used USA on eBay).
    Oct 2023
    7
    Re: Internal thread cutting tools
    Hello, we are manufacturer of cbn insert from China.
    We can give you advice about how to choose insert.
    Welcome to enquiry.
    Whatsapp: +86-18282557341
    E-mail: [email protected]
    Oct 2023
    we are a manufacturer of custom clothing products from Pakistan named <a href="https://foxedosports.com/">foxedo sports</a>. If you want any custom products visit the foxedo sports website.
  1. Uncommon metric thread cutting on an inch machine (M48x0.75) - Thread cutting wizard
    By nateman_doo in forum Machines running Mach Software
    Last Post: 08-13-2021, 08:43 PM
  2. Help : Wrong Thread is cutting for Internal Metric Thread
    By dolarpond in forum G-Code Programing
    Last Post: 06-02-2017, 04:51 PM
  3. Help : Wrong Thread is cutting for Internal Metric Thread
    By dolarpond in forum Chinese Machines
    Last Post: 06-02-2017, 08:01 AM
  4. Thread milling a 1/8-27 npt internal thread
    By Slick27 in forum BobCad-Cam
    Last Post: 02-17-2016, 07:58 AM
  5. Lathe - internal facing tools?
    By kong in forum Uncategorised MetalWorking Machines
    Last Post: 03-09-2009, 07:26 PM
