586,106 active members*
3,019 visitors online*
IndustryArena Forum > MetalWorking Machines > Knee Vertical Mills > Parallelism of the table adjustment
    Aug 2007
    12
    Greetings,
    Is there any way to adjust parallelism of the table? I have a BP clone, Lagun by name, and just discovered the table is way out of parallel along both the X & Y axis.
    I have a dial gauge in the chuck with the tip on the table. When I move the table along X or Y the gauge moves showing the table in not parallel to the spindle.
    Is there any hope?
    Kerry
    Dec 2005
    3319
    Not to insult you but mMake sure you're not reading an out-of-square/mismachined tablle "side" or slot...
    All that being OK. you just might have to dust off the slots to square them up with/to the spindle. Might have to make/use oversized "T" nuts but at least it would salvage the mill.
    Dec 2006
    51
    Do you have the indicator on the table surface or against a vertical surface ( T-slot/side of table) ?
    If you have the indicator against the top surface of the table, then I'm not suprised, the table on knee mills tend to "tip" when moved to the extent of their travel i'd say up to .005" on a well used machine, adjusting the gibs may help.
  1. Gibb adjustment help
    By TT350 in forum Tormach Personal CNC Mill
    Last Post: 11-15-2007, 03:04 PM
  2. QC Nut adjustment
    By zcases in forum Bridgeport / Hardinge Mills
    Last Post: 06-11-2007, 03:10 AM
  3. how can i measure parallelism of 2 linear slide?
    By cnc2k in forum MetalWork Discussion
    Last Post: 03-13-2005, 04:26 PM
  4. Slide adjustment?
    By freezer in forum DIY CNC Router Table Machines
    Last Post: 02-21-2004, 05:17 PM
