Re: How to Select a 4TH Axis
Originally Posted by
kolias
What “skewed rotor” means?
BTW a Skewed rotor means that the armature winding lamination are skewed instead of being straight which gives it a much smother rotation at low RPM's, IOW Servo rated.
It also is important to have the ability to add an encoder, if it does not already have it.
The one shown has the rear shaft for possible hollows shaft encoder add on.
Albert E.
