Hello, I have noticed a problem with our machine which started a bit ago, but doesn't happen all the time. When you press the arrow key to move the machine, it doesn't mover right away. When if does, it will move more then expected from the time I let go of the key. I suspect that its a delayed signal and the amount the machine is moving is based on how long I had the key down. So it will delay starting to move but will continue to move equal to the time I had the key down. Anyone have this issue before or know what I should start to look at to resolve this. The machine is an Avid bench top machine with there controller setup. Machine has worked fine and nothing has changed, besides maybe a few windows updates. Its just odd because it only happens once in awhile.
