586,042 active members*
3,750 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > holding thin material on lathe
Results 1 to 16 of 16
    Nov 2004
    202
    I need to turn a very thin aluminum piece on the lathe. It seems like somewhere I have heard of glueing thin stock to something thick enough to hold in the 4 jaw chuck and then use heat to take the pieces apart after the turning is complete. The trouble is I cannot remember anything about the technique beyond that. Can someone help me with the details please?
    Thanks in advance:wave:
    Sep 2007
    217
    How thin? Thur hole? I have used hot glue, I have used lead, I have used primer on a part and super glue. I have made disk larger than what I need then do cut off the excess. There are a lot of different ways in which to approach this.
    Mar 2005
    1136
    like crazy says, more info would be good. if its sheet metal thick, put something in the 3 jaw, face clean using a fast feed - better to leave some marks - the spiral will help hold. face another piece and centre drill on the opposite side. sandwich the work between the bung and the headstock mounted piece. The two pieces you made are slightly expendable, the work and sandwiched between and all are cut together. take light cuts. you can use double sided tape but I've found this creates surface that doesn't support the work at the cut, that is when you are cutting thin stock. for thicker stuff, use carpet tape and for thicker still use a three jaw spider
    Jun 2007
    3757
    Wink Try Shellac
    If its flat, on a face plate, glue it on with shellac.
    Soak in methelated spirits to remove with no damage.
    If you take a skm on a faceplate first, glue to it, then machine you can make VERY thin parts.
    Nov 2004
    202
    Smile
    wow thanks to all of you.
    The piece in question is a thin aluminum casting which is a cylinder head for a model steam engine. The circumferance doesn't require turning. One side needs to be faced off. The whole thing is not thick enough to be held in a chuck securely and there are no holes in it. Sorry I wasn't more descriptive in my orginial post. I have save all three post in my tips folder.
    Jul 2005
    442
    Sounds like the head for one of the PM Research engines
    chuck up some scrap ~1/2" diameter larger than the casting and bore a recess to hold the casting in - superglue in place, turn and use acetone to remove.
    Use the same fixture to prep the other head but don't through drill for the piston rod - drill and ream with this part glued in the cylinder after you bore the cylinder before you pull it from the chuck.
    Aaron
    Jun 2007
    98
    MiteeBite makes a product that is like a wax paper that you heat up with a heat gun , then stick the parts on . You release it by butting it in a pan of hot water
    Nov 2004
    202
    Smile
    Quote Originally Posted by chipsinpan View Post
    MiteeBite makes a product that is like a wax paper that you heat up with a heat gun , then stick the parts on . You release it by putting it in a pan of hot water
    Thanks chipsinpan, I found their website and have sent them an email.
    Aug 2005
    300
    Holding thin material in lathe
    If you have removable jaws for your chuck you can make a set of soft jaws. You then bore the jaws to size and to a depth shallower than the thickness that you want to cut. This is a way to hold a piece very securely and accurately in the lathe.
    ErnieD
    Jul 2007
    195
    try a 6 jaw chuck!
    They are made for thin or fragile parts, just take it easy.
    Be carefull what you wish for, you might get it.
    Nov 2004
    202
    regarding soft jaws and 6 jaw chucks
    Thanks ErnieD and Jrom,
    Both viable suggestions, but not available on my little hobby lathe. In the past I have used the soft jaws to good advantage. That was on a much larger lathe then I have at present. What I have now is a tinker toy by comparison. The closest I could come to that is by using the face plate and making a fixture on it. Anyway thanks for the input it is good to have all of these suggestions. Thats what I like about CNCzone.:wave:
    Aug 2007
    80
    Depending on the thickness. Use double stick tape
    Aug 2011
    hold thin plate in lathe
    Hi
    Iam brand new here
    i need to do machining in lathe tungsten material
    final size of product is 75mm dia and 3mm thick.
    i unable hold on chuck 3mm thickness(chair).. i need to turn solid pieces without center hole.
    any one can give me good idea for holding on lathe or milling
    ..in my work shop manual lathe and manual milling m/c aviliable for machining..
    can send reaply to my email. [email protected]
    Jnanes
    Nov 2004
    202
    I have been told this will work, but I have not done it myself. The man that told me this was a clock smith.
    Turn a piece of wood to the correct diameter. Super glue the metal to the wood for turning. Use a propane torch to release the metal from the wood after you are finished turning. Super glue is not a high temp material and will lose bonding strength if heated.
    Perhaps others will verify if this works.
    Aug 2011
    Thin plate
    Thank Q for ur valuable idea.. We already try but not good enough to hold for machining ..
    We can try sandwich in-between chuck and tailstock .. !
    We still need good enough for it
    ThankQ
    John:drowning::drowning:
    Jun 2007
    3757
    Sandwich is good.
  1. Lathe spindle bearings and spindle material
    By mackeym in forum Uncategorised MetalWorking Machines
    Last Post: 08-21-2007, 08:49 PM
  2. Lathe spindle bearings and spindle material
    By mackeym in forum Linear and Rotary Motion
    Last Post: 08-11-2007, 04:53 PM
  3. Custom lathe spindle material?
    By tdpyro in forum Mechanical Calculations/Engineering Design
    Last Post: 09-29-2006, 06:11 PM
  4. Material for lathe bed question
    By jdholbrook in forum Uncategorised MetalWorking Machines
    Last Post: 05-01-2006, 05:05 PM
  5. Holding down material
    By swoolhead in forum DIY CNC Router Table Machines
    Last Post: 10-04-2005, 09:48 PM
