586,116 active members*
3,440 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > nose radius compensation in fanuc tb-mate
    Feb 2006
    37
    hello,
    we are face grooving profile grooves on aluminium castings, we have taken co-ordinate points for the profile from the Autocad drawing,we face a problem of radii at different points in the groove measuring either in excess or reduced to the extent of tool nose radius of 0.4mm when compared to the drawing which is attached with this message
    any suggestions
    thanks
    rags
    Attached Files Attached Files
    Feb 2006
    992
    are you plan to do this on lathe or mill?
    The best way to learn is trial error.
    Feb 2006
    37
    thanks cnc turning
    rags
  1. G143 Nose Radius Comp. - Hitachi Seiki HT23J
    By jbird68 in forum G-Code Programing
    Last Post: 05-07-2021, 01:00 PM
  2. tool nose radius comp
    By joe1970 in forum G-Code Programing
    Last Post: 02-25-2010, 04:43 AM
  3. Fanuc 5 axis radius compensation
    By d.a.v.e in forum Fanuc
    Last Post: 10-06-2008, 08:52 AM
  4. Fanuc 5T Tool Nose Compensation
    By John3 in forum Fanuc
    Last Post: 07-16-2007, 04:58 AM
  5. Tool Nose Radius Fault with Program
    By Josh-PTP in forum Haas Mills
    Last Post: 06-30-2007, 11:03 PM
