Hi Guys
I am finalizing the wiring between my Keyboard and Computer and have a question on hooking up the USB Devices. Can you run the Shuttle Jog Controller from one of the Mini Keyboard USB connectors or should you run a separate USB line back to the Computer? What about for the Mouse and USB Hub? I understand that normally, USB devices can be plugged into each other but I am not sure if this is true with CNC controls?
I will have the following USB items:
(1) Keyboard
(2) Mouse
(3) Shuttle Jog Controller
(4) USB Hub for Memory Stick.
Should I run separate USB lines for each item or can they be piggybacked?
Thanks for your help.
Willy
