586,082 active members*
3,772 visitors online*
    May 2006
    214
    Protect your G54...G59
    Robodrill Fanuc 21i
    Is there a parameter settings to avoid all this numbers (coordinate systems)to get deleted, an operator a work push the "clear" key and wipe them all out.
    And yes...I do not have back ups. I am working in setting them back but after a save a back up I would like to know if there is a way to lock these numbers with a parameter, macro, whatever.
    Al the man, I bet you know this one.
    Thank you all in advance.
    Jorge
    Aug 2007
    21
    Solution
    Normally, we use G10 on the top of the program.
    Ex.
    O1234;
    G90G10L2P1 X_Y_Z_;
    P0 = Ext.
    P1 = G54
    P2 = G55
    P3 = G56
    P4 = G57
    P5 = G58
    P6 = G59
    You can lock you coordinate system by this way.
    Good luck.
    May 2006
    214
    Smile
    Yes...I hear about G10
    Can you please be more specific with the description of each address (letter)
    PO= Ext. what is Ext????
    L2= what is the meaning of L2?? and
    P1 obviously is G54 etc etc.
    Thank you in advance.
    Jorge
    Feb 2007
    464
    Quote Originally Posted by jorgehrr View Post
    Jorge
    P0=Ext means it's an External offset that you normaly set to zero on all axis.
    And you can't program it with normal G codes.
    If you change it to anything other than zero it will affect all other work zeros.If you have a HMC though, some people (like me) program it.
    L2 is used when you set P1-P6(G54-G59)using G10,L20 when you use all 54 (48+6) work zeros.
  1. "memory protect key"?
    By N.T.C-Guy in forum Fanuc
    Last Post: 01-08-2007, 07:20 PM
