586,599 active members*
3,525 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Mastercam Question
Results 1 to 6 of 6
    Mar 2004
    500
    Mastercam Question
    Hi all,
    I was just wondering what units Mastercam is in, I know this sort of sounds stupid, but I'm not totally sure. Not only for measurements, but also for things like speed and feed rate.
    Thanks. :rainfro:
    499
    Its in where ever you want it .
    Go into your config.
    Screen, config, nc-settings and change current config file
    (lower left) in V9.
    PEACE
    Mar 2004
    500
    So for cutting speeds and retract rates, what are the units? It just says something like 200 or 400, but 200 or 400 what??
    Thanks. :rainfro:
    Apr 2003
    3578
    well were are you looking in the Matrial call out this could be surface feet.
    or if you are in Metric for the standard pramaters pages.
    What are you using as a standard so we can better help?
    Cadcam
    May 2004
    lathe or mill ?
    you need to set values in screen cfg.
    and each tool defaults are never right
    always check the posted file for speeds
    and feeds until you get a little experance
    with the program it's easy when you know how
    remember error on too slow or move your puter
    away from machine much good luck
    Karl
    Apr 2003
    1876
    Re: Mastercam Question
    Originally posted by Sanghera
    Hi all,
    Thanks. :rainfro:
    RPM, Feed rates, Retract rates etc. are in Revolutions per Minute and Inches or Milimeters per Minute depending on what you're looking at.
    There's a TON of help associated with each control in almost every dialog box. Use the "?" at the top right corner of each dialog to get the tool tip help shown below, and definately READ the help files. They are invaluable.
    Matt
    San Diego, Ca
    ___ o o o_
    [l_,[_____],
    l---L - □lllllll□-
    ( )_) ( )_)--)_)
  1. Mastercam with *old* Hurco CNC Miller
    By ReValveiT in forum Mastercam
    Last Post: 05-19-2006, 01:01 PM
  2. MasterCam 4th axis project question
    By HomeCNC in forum Mastercam
    Last Post: 12-13-2005, 01:17 AM
  3. Replies: 2
    Last Post: 06-08-2005, 12:58 PM
  4. Mastercam Jingle Bells
    By Rekd in forum Mastercam
    Last Post: 01-02-2005, 08:20 PM
  5. Newbie Question MasterCAM Mill for Router
    By Sanghera in forum Mastercam
    Last Post: 04-28-2004, 04:41 PM
