586,070 active members*
3,556 visitors online*
IndustryArena Forum > MetalWorking Machines > Bridgeport Machines > Bridgeport / Hardinge Mills > Help..Stuck at relay ext dc voltage missing but dc voltage OK ?
Page 2 of 2 12
Results 21 to 27 of 27
  1. #21
    Sep 2007
    69
    Thanks Mark....if i followed Gus,s advice I would be in flames right now...tee..heee.heee 8-)......just jokin Gus.....Well guys...here it is....found the fault....It was in the heidenhain control itself.....One of the resistor-fuses that are used to protesct the control circuits was burnt "open".....replaced it...and now that all the other things are repaired....ITS ALIVE!!!!
  2. #22
    May 2004
    402
    Glad you are now working at last. I do recall saying quite some while back:
    "Did the 24v DC fail in a mode that put significantly higher, or maybe AC, volts onto the TNC - if so has the 24v input on the TNC let the magic smoke out?"
    Andrew Mawson
    East Sussex, UK
  3. #23
    Sep 2007
    69
    you certainly did look at that post or your pm messages...I replied to it and thanked you for the direction
  4. #24
    Nov 2007
    6
    voltage
    Did you ever figure this problem out?
  5. #25
    Sep 2007
    69
    Yes I did...with the help of my huge brain.....no...seriously.....with the help of all the folks here. How can I help you ?
  6. #26
    May 2021
    6
    Re: Help..Stuck at relay ext dc voltage missing but dc voltage OK ?
    I have the same problem on a tnc 145 i cant find diagrams for it though, any idea where these resistor-fuses are found?
  7. #27
    May 2021
    6
    Talking Re: Help..Stuck at relay ext dc voltage missing but dc voltage OK ?
    Found it all on my own!
    Resistor next to J1/8 blown although didn't look black meter caught it.
    all working!
Page 2 of 2 12
  1. BT Interact 412 - RELAY EXT. DC VOLTAGE MISSING
    By Zhales in forum Bridgeport / Hardinge Mills
    Last Post: 10-19-2017, 03:19 PM
  2. relay ext dc voltage missing
    By hdts in forum Bridgeport / Hardinge Mills
    Last Post: 01-02-2015, 12:22 PM
  3. relay ext. dc voltage missing error on tnc 150 B
    By M535 in forum Bridgeport / Hardinge Mills
    Last Post: 05-07-2013, 12:20 PM
  4. relay ext dc voltage missing in TNC 351
    By moghul in forum Bridgeport / Hardinge Mills
    Last Post: 01-29-2013, 02:03 AM
  5. Relay ext, dc voltage missing
    By fastcarl in forum Bridgeport / Hardinge Mills
    Last Post: 11-18-2010, 01:57 PM
