586,655 active members*
3,095 visitors online*
Results 1 to 18 of 18
    Exclamation Rabbit Laser not working
    Hello everyone. Found the forum. Great site. I recently purchased a Rabbit HX6090SC. got it home worked great. The second time I used it the power supply blew. Fan inside was un pluged and over heated. Received a new power supply but not the same. Same wattage but for one of their other machines. They said it would work. Have it installed the way they want it but the laser fires just won't leave the tube ! The laser seems to arc at the metal ring whrer you make the connection for the ground on the laser tube. Any Ideas ? Any one ever hear of this ? I replaced the laser tube with a spare I bought, same thing. Any help would really be great. Thanks, Jim
    Aug 2007
    61
    Wish I could help. Maybe next week once mine goes down. These machines have to be tested before they leave the port!
    Jul 2007
    8
    Help please.
    My new CO2 laser machine has a a working area of 1000mm X 600mm. The software came with the machine is the DSP5.0. The machine only gives about 50% working area around the center of the machine table.
    Here is what I want to cut:
    [IMG]E:\WorkingTable.JPG[/IMG]
    Then I got this message:
    [IMG]E:\Exceeds working table.JPG[/IMG]
    Here is the machine setting at the default setup of the software:
    [IMG]E:\Laser_Machine-Option_Worktable.JPG[/IMG]
    Thanks.
    I guess I have problem to attach pic here.
    Attached Thumbnails Attached Thumbnails WorkingTable.jpg   Exceeds working table.JPG   Laser_Machine-Option_Worktable.JPG
    Apr 2007
    641
    In the software screen Go to file/options/worktable there you can set the size of your table. After that go to printing icon in the software screen and download the config. import the PLT or AI file and download it to the machine.
    Use corel 11 to draw export as .PLT . Import to the machine software
    Here in the forum to download pictures: go advanced
    Jul 2007
    8
    [QUOTE=Laser123;350253]Help please.
    Thanks.
    I guess I got the attachments here now.
    Sep 2007
    11
    [QUOTE=Laser123;350970]
    Quote Originally Posted by Laser123 View Post
    Help please.
    Thanks.
    Please follow these steps:
    1- delete all the letters in you drawing except one, ( for example the inner circle of th O letter.
    2- click on the 10th button from the left in the button bar, ( zoom to the object).
    3-if you cannot see the shape that you left in step 1 filling all the screen that means there are more line outside the working area, check you design.
    I hope that helps
    Apr 2007
    641
    When you receive your machine did it come with the size of the table or it was 900 x600 the input? If so, Did you download the config in the laser output? Because you can have that config in your PC as you say onlu have about 50% of centered working area... please check it
    Apr 2007
    641
    Jim Dornon, That arc coming out from the tube, check if the welding has picks , if it is not plain, that can make thi current to jump like that.
    Other thing is that the tube could have broken the internal conections for the catode and anode.. BE CAREFULL WITH THAT WIRES 20.000 volts there!!!
    Laser
    Welding pics. Do you mean were I soldered the connection to the laser tube ? Jim
    Rabbit Laser HX6090SC
    Apr 2007
    641
    yes in the anode and catode wires, the weld should be clean , no high points (picks) wire left as a needle, the arc jumps from there
    Aug 2004
    2849
    So, where the Rabbit Lazer Guy.....he always was running around he saying how he could help...Quality Number One....etc. and his little partner aka nemesis....
    Aug 2005
    14
    hello guys as a distributing of laser machines in israel i will be happy to give u solution
    did u download the new machine cfg file?
    downloading the cfg file with correct setting should solve the problem.
    CAT
    Question I don't understand
    Not sure I follow. Can you explain ? Jim
    Aug 2005
    14
    ctrl+y will center all the job then use the "zoom to all object "on top-if there is some job out of the working area it will show it.
    if its a dsp offline machine u should download first the machine parameters as a cfg file-all details inside like the working table size......
    DID ANY ONE NOTICE A BUG IN THE 5.0 VERSION?
    only dspoffline version?once u want to download the file ,on the prossesing part the software jumps out-i am still waiting for solution from the software company.
    did anyone else got the same problem?
    Apr 2007
    641
    Yes I have seen it , we reinstalled sofware and it dissapear but not at all. sometimes it jumps again
    Aug 2005
    14
    hello lamicron
    do u have the dsp5.0 and u use dspoffine machine?
    can u please back up the "language.ini"file and delete
    then let me know if this problem apear again?
    is it jumping out only on the calculating data part?
    we think this problem apear only if your windows is not english version .But we are not sure yet.
    thanks
    CAT
    Apr 2007
    641
    Yes , now we know the spanish XP version doesnt work well, it took a long time to know it.
    I don't understand the other questions
    Aug 2005
    14
    hi again
    do your machine is USB ?
  1. Rabbit hx720
    By kk_krissy in forum Printing, Scanners, Vinyl cutting and Plotters
    Last Post: 10-31-2012, 11:34 PM
  2. Rabbit laser:need help
    By pbucha in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-04-2012, 03:39 PM
  3. I met Frank with Rabbit Laser
    By pedroman in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 03-19-2009, 11:19 AM
  4. Thanks Frank / Rabbit Laser and Dean @ the-lasersedge.com
    Last Post: 10-26-2007, 09:32 PM
  5. Rabbit HX5070S vs.IE500 Laser engraver
    By gprocket in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 06-24-2006, 12:33 PM
