586,115 active members*
3,458 visitors online*
IndustryArena Forum > CNC Electronics > Phase Converters > HELP!! How do i get the best size Rotary Phase Converter?
Results 1 to 6 of 6
    My shop has grown, and all my bigger machines use 220VAC 3Ph. So far I have a 2hp motor, a 3/4hp motor and a 1/8hp pump. The problem I have is that a static phase converter can not run a fractional hp motor!
    I was told by an electrician that I need to get a Rotary Phase Converter, one big enough to run all my machines! But they are not cheap! So I want to get one that I can afford, and one that will fit my motors!
    Does anyone know how to choose the size of Rotary Phase Converter?
    Widgit
    24221
    Quote Originally Posted by widgitmaster View Post
    Never heard of that, how come it cannot run a fractional?
    The sizing of the RPC depends somewhat on what type of loads you have, i.e. transformer or 3 phase motor?
    Any three phase motor is usually considered to aid the RPC.
    IOW, if you had purely 3 phase motors as loads, the understanding that I had is that you could supply approximately twice the HP load as the RPC as long as the largest motor was no larger than the RPC itself.
    Al.
    Albert E.
    Hi Al,
    My electrician responded with the same question!
    The tech for the RPC informed us that their company Phase-A-Matic has been unable to make a static phase converter for fractional motors.
    If I read your reply correctly, all I need is 2hp RPC to satisfy the needs of all my motors!
    Eric
    www.widgitmaster.com
    It's not what you take away, it's what you are left with that counts!
    Jul 2005
    12177
    This digital phase converter has been mentioned in a few threads.
    http://www.phaseperfect.com/
    It is not cheap but most posters who have it seemed happy.
    Aug 2006
    281
    I ended up buying a 7hp American Rotary phase converter (http://www.americanrotary.com/). After searching prices, it was by far the cheapest rotary I could find but it's very nice. 7 HP was the smallest they have that's CNC rated. I don't know how important that really is but it works good. I believe they recommended double the motor HP of your biggest motor on the system. You could run all of your equipment from it then. In many cases you could run them simultaneously if you started the big machines first.
    My understanding is that Digital Phase converters will only give you 2/3 the power as the third leg is only momentary for start-up. I looked at that PhasePerfect web site and it didn't look like it did that though.
    After talking on the phone to a local electrician, he recommended a 5 hp RPC! So I took his quote, and several others, and ended up buying one on eBay that is made by Baldor for $340
    This weekend I will be installing the unit in my garage, and it's not a small project! First I had to figure out where to put the RPC, then I needed to locate a home for the control box. The box is 8" deep, so I cut out the drywall and recessed it to the wall! Then I had to go shopping for 3 phase twist lock plugs & sockets for all my machines. Lastly I will have to remove all the static phase converters currently in use, as they are taking up valuable space!
    After lurking around Home Depot, I realized they do not sell any electrical components for 3-phase! So I had to get everything from Granger Industrial Supply! One thing for sure, I will not miss that annoying hum from the Static phase converters!
    Widgit
  1. Emco120 CNC lathe and 15HP Rotary Phase Converter
    By JRouche in forum Phase Converters
    Last Post: 06-17-2015, 04:14 AM
  2. Rotary phase converter for Bridgeport 2J Series 1 KM-1 2HP setup?
    By modernprecision in forum Bridgeport / Hardinge Mills
    Last Post: 07-02-2007, 12:43 AM
  3. Re: Rotary Phase Converter - Deckel
    By T_Rex in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 06-25-2007, 09:48 PM
  4. AC unit -> rotary phase converter?
    By loves80z in forum Phase Converters
    Last Post: 11-02-2005, 11:23 PM
  5. Rotary Phase converter problems
    By Gnome in forum Phase Converters
    Last Post: 06-15-2005, 03:43 AM
