586,082 active members*
3,585 visitors online*
    May 2007
    163
    Replacing steppers for servos
    I have a 14x40 lathe that I’d like to covert to cnc
    so I was thing of replacing me steppers on my
    Tormach with servos and using the leftovers for
    my lathe. Can some on tell me what’s involved
    in doing this. Can replace the motors and the drives
    and reconfigure Mach 3 or
    Nov 2004
    284
    Hi TT350
    Well other than swapping out the Stepper Drives for Servo units, you would likely need to also install a Belt Drive between your Servo Motors and the Ball Screws? Most of the Servo installations I have seen (non Tormach) are DC Brushed Servos with a Belt Drive reduction. This could depend on the type of Servo Motor you plan to use. The higher end machines that are using Brushless A/C Motors tend to be direct drive. The Power Supply would also likely need replacing to match the voltage of your new Servo Motors? Hope this has been some help.
    Willy
    Oct 2006
    669
    There are several companies that offer servo swaps for stepper machines, using servodrivers that accept step/direction commands. SureServo comes to mind. Power supply is going to be different, although you'll probably want to add a new one specifically for the AC servos (SureServo) as you'll still need your old power supply for the other existing components. My thought would be to buy a GREX 101 from Gecko, as you can send step/direction commands to the SureServo drivers from it and also accept inputs from the encoders. Direct drive would be your best bet, but you'll have to put "speed" limits on your servos so you don't get ballscrew whip, as one end of all the ballscrews are floating on the Tormach. Unless you feel like maching some end mounts for your ballscrews and installing them before you do the servo swap. Or...if you are just looking at using the Tormach motors for your lathe, Tormach offers them as machine components for sale separately. Just some FYI.
  1. Do you use steppers or servos ?????
    By KEYTEEM in forum Polls
    Last Post: 07-05-2016, 12:49 PM
  2. All in one steppers and servos.
    By J Solinger in forum LinuxCNC (formerly EMC2)
    Last Post: 09-29-2006, 07:42 AM
  3. Steppers and Servos...
    By ger21 in forum FAQ of DIY CNC Machine Building
    Last Post: 02-24-2006, 04:45 AM
  4. Servos or steppers
    By Paul in OK in forum Commercial CNC Wood Routers
    Last Post: 11-17-2005, 10:11 AM
  5. steppers vs. servos
    By twombo in forum DNC Problems and Solutions
    Last Post: 06-10-2003, 08:43 PM
