586,103 active members*
3,234 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Visual Basic > Line Smoothing, point /line no identification
Results 1 to 9 of 9
    Feb 2007
    58
    Going to be posting a new (small) project soon. Needed the following:
    - way to easily strip all negative Z offsets from traditional CAM program for using program with plasma table
    - way to smooth out curves composed of an ton of G1 points so machine would run faster/smoother
    - way to corrolate line numbers with points in a drawn display so I can exclude a certain range of code lines from the smoothing operation
    done with 1 and 2, just finishing up 3. if anyone has any other ideas for useful features that arent huge let me know. (will be open source)
    features like using it to just renumber lines can be done trivially at this point.
    works by parsing/manipulating CAM generated gcode files not graphics based
    images
    Oct 2007
    Eliminate Z Jitters
    I have been looking for a G-code smoothing program that would eliminate small z moves as in the codes shown below.
    X1.8959 Y-.212
    X1.8942 Y-.2261
    X1.8925 Y-.2403
    X1.8907 Y-.2544 Z.0251
    X1.8887 Y-.2686 Z.025
    X1.8866 Y-.2827
    X1.8845 Y-.2968
    X1.8822 Y-.311
    X1.8799 Y-.3247
    X1.8773 Y-.3392
    X1.8747 Y-.3534 Z.0251
    X1.872 Y-.3675
    X1.8691 Y-.3816 Z.025
    X1.8662 Y-.3958
    X1.8657 Y-.398
    X1.8632 Y-.4099 Z.0251
    It should be simple enough. Let me know what you think.
    Grantman
    Feb 2007
    58
    good idea grantman, will add that and allow user to specify how much difference to ignore
    will probably upload this weekend sometime.
    Feb 2007
    58
    attached, please see readme.txt before use
    as always safety is up to the operator, no results guaranteed standard disclaimer blah blah
    requires vb6 runtimes and comctl32.ocx
    Attached Files Attached Files
    Oct 2007
    Thanks DZ1,
    I'll check out your program and let you know what I think.
    Oct 2007
    DZ1,
    Worked great. Eliminated hundreds of small z moves that previously made small
    gouges in my parts. Thanks again!
    Does this combine small moves into longer straight moves, or does it combine them into arcs?
    Feb 2007
    58
    glad to hear it worked well for you grantman
    ger21, it only removes G1 points does not ( or rather shouldnt touch any arcs...so a smooth of 3 would take out 3 sequential G1 points skip one, take out another 3, most of my parts are from bitmap traces so all i ever get is g1 point clouds
    one possible bug i have encouintered is if you have a section with a striaght line like for a framed piece, if you dont exclude teh right lines of code you might end up with a not so stright line as one of the square points of the frame got wacked...thats where the feature to figure out which point is which line number and the exclude/include lines feature comes in
    156
    Data points unless they lie on an axis plain cannot be readily made into arcs. But points along an axis plain can be grouped in 3's and made into short connecting tangential and non-tangential arcs. for smoother moves.
    Safety - Quality - Production.
  1. Dm2400 Line By Line Execution????
    By andrewtub in forum Benchtop Machines
    Last Post: 01-26-2010, 05:28 AM
  2. What side of the line??
    By becikeja in forum BobCad-Cam
    Last Post: 08-11-2007, 07:07 PM
  3. line arc line
    By THE GREAT ONE in forum MetalWork Discussion
    Last Post: 01-23-2006, 09:43 PM
  4. line from point in angle
    By JSandSO in forum Autodesk
    Last Post: 01-29-2004, 03:28 AM
