How do i drippfeed my matsurra mc500-v.
I use Cimco to send program.
How do i prepare the machine for rechive. I think i should use the tape mode. But how do ill start the machin for rechive?
Please help me.
Please help me.
What control does it have?
The control is Yasnac
Great. Which YASNAC? M5, M5-G, M5-GII, MX1, MX2, MX3? I believe the later ones could drip feed, the earlier ones couldn't.
Im not sure but, i think it is a mx 2.
I think one of my machines is a mx3
I have the following models of matsuura with yasnac
VX-1100
RA-1 With pallette.
MC500-v
Two of my machines has MX3- And one of em has MX2
Try this. Put the machine in Tape mode. Turn on the Single Block switch. Hit Cycle Start. LSK should blink? From the PC, send the program. At NC, turn off single block, hit Cycle Start. (It's only been 25 years or so since I last did this, so my memory is a little fuzzy.)
Thanks, it help me alot. Now the machine is rechiving something, but ill get an alarm with overun. Ill think it is a settings. But now i have something to work with.
Thanks alot.
Martin
Working perfect now. I was cheatet because the screen dosent show anything while running in tape mode. Cant u see the program from the computer while it running. So u can see what the machine will do next?
check and see if the software has a terminal mode than you can see the data output but it will be buffered in the machine
