Hi good day CNC Zoners. First of all, I wasn't really sure where to post this thread so decided to post it in here. MODs are welcome to move it where it belongs. I am a newbie on CNC and bought this cheap CNC thru ebay ( CNC 3040) Now I can't get it to work. I have no idea how I am going to troubleshoot this machine. I'm thinking of lots of factor that might be the problem with this. First, If I installed the software right. Is the Parallel adapter working? The cnc axis controller isnt working? Motors not working?
So first, I have freshly installed Windows XP on my computer and connected everything as what it says on the maunual. After testing it out, none of XYZ is moving. Tho, the spindle is working if you control it manually on the CNC controller. I set everything correctly on the Mach 3 software includng the port number. Then after, I connected the parallel port and the USB cable. It's still not working. I even tried to use two different computer and even, an old Dell laptop just to try my luck, but all didn't work out. I also tried re-installing everything and all didn't work as well. I also check the hard ware on device manager and it says that it is working fine. Lastly, it seems that the XYZ motors are locking up once I turn the driver switch on. is that normal? Can you please help me out with this? Thank you.
