586,114 active members*
3,330 visitors online*
    May 2006
    214
    Smile Absolute and relative
    I'm new with machine centers.
    I mix both when I program lathes (X,U) (Z,W) with out any G code just input the address.
    In machine centers can you do the same or you need the G code?
    Also, I see an "A" in one of the programs what axes does this have relation with.
    Thank you in advance.
    Jorge
    24221
    A axis will be rare on a lathe, but the convention is that A rotates around X.
    B rotates around Y & C rotates around Z.
    A,B,C axis for rotary tables for e.g.
    On a lathe, if the spindle is used for a Rotary, then it is C axis.
    Al.
    Albert E.
    May 2006
    214
    Thank you Al,
    Here is a couple of blocks where I see the "A". I really do not understand why the "A" is in there.
    N4 T1 M6
    N6 G0 G90 G54 X0. Y0. A0. S1426 M3
    N8 G43 H1 Z1.
    N10 Z.1
    N12 G1 Z-.3 F6.3
    Thank you
    Jorge
    Jul 2005
    12177
    Quote Originally Posted by jorgehrr View Post
    Thank you Al,
    N4 T1 M6
    N8 G43 H1 Z1.
    N10 Z.1
    N12 G1 Z-.3 F6.3
    Thank you
    Jorge
    A is the 4th axis on a VMC which would be a rotary table mounted on the machine table with the axis of rotation horizontal and parallel to the X axis.
    On a machining center Absolute and Incremental (Relativee) commands are selected by G codes; G91 is Incremental, G90 is Absolute.
    May 2006
    214
    Thank you guys for your help.
    Jorge
  1. Fanuc 0M.. how do you zero relative?
    By OC_ in forum Fanuc
    Last Post: 02-24-2007, 05:45 AM
  2. relative position
    By Rocksalt in forum Fanuc
    Last Post: 10-24-2006, 08:17 PM
  3. x/y absolute dimensions (how?)
    By corpse in forum Solidworks
    Last Post: 02-03-2006, 06:31 PM
  4. Absolute encoders?
    By murphy625 in forum CamSoft Products
    Last Post: 03-29-2005, 04:18 AM
  5. Absolute and Incremental
    By ACME in forum G-Code Programing
    Last Post: 09-04-2004, 11:45 PM
