Hi Brian..
Sorry I missed this thread earlier. I went through what you're going through now with a FX20.
First things first.
Dan Fritz is THE MAN when it comes to these older Fanuc controls. Pay attention to what he tells you, he
will be able to help you.
Regarding RS232: 5T controls have no way to send or recieve programs via RS232. If your machine has a serial port, then it has some type of aftermarket BTR interface board installed. If you get it to work, then more power to you. However, I strongly recommend Dan's PC-DNC software and cable. It's freakin awesome and adds a lot of functionality to the old 5T controls. **
If you don't have the manual with the options listed you're in trouble. Heck, I had the manual and factory parameter list for mine and many of the parameters in the manual were WRONG for what the machine was equipped with.
If you have the complete Ikegai manual set there should be a mostly complete list of parameters somewhere. The FX25 machines are very similar to the FX20 machines. If worse comes to worse, you can try using the parameter list I posted earlier in one of my threads. Search for my previous posts to find it.
Next: I don't know how far you've gotten in getting this machine running, but if it has sat for 2 years then you MUST rebuild the lube system. Way lube gets very crusty and will completely plug the orifice fittings on the machine. You MUST replace or clean these before operating the machine on a regular basis or you WILL kill it. Unfortunately Ikegai did not mount the fittings in central location so quite a bit of machine disassembly will be required to get to them all. All of the tin will have to some off the machine, etc. Don't get lazy and skip this. It's quite a bit of work but it's
extremely important you do this!
While you have it apart to refurb the lube system, check the backlash and rebuild the ball nuts and replace the thrust bearings while you're at it. It's not that much more disassembly to do while you're there.
I'm really impressed with Ikegai machines. The iron is top notch and way overbuilt for their machines. It's a pity I have limited room as I really would have liked to keep mine.
Oh, where in Canada are you located?
Michael
**Disclaimer: I'm just am extremely satisfied user of PC-DNC and have not been compensated in any way.
