586,075 active members*
3,704 visitors online*
Thread: TM-1 vise
Results 1 to 7 of 7
    Sep 2007
    97
    TM-1 vise
    Is a 6" milling vise like a Kurt 675 or 688 going to work ok with a TM-1 that has the factory chip shields on it without hitting anything? I have a TM-1 on the way I want to get some tooling and a vise on order too.
    Jul 2007
    195
    Yes
    Be carefull what you wish for, you might get it.
    Dec 2006
    447
    I have a TM-1P which I think is nothing more then a TM-1 with an enclosure and a tool changer. The 688 mounted on the center "T" slot leaves you about one inch of clearance on the back side. I had to cut almost an inch off the handle stub to clear my enclosure but that should not be a problem for you.
    Vern
    Sep 2007
    97
    Vise on order, thx for the help guys!
    Jul 2004
    601
    Also get the 5/8 vice keys. They sure help getting the vice dialed in!
    On all equipment there are 2 levers...
    Lever "A", and Lever F'in "B"
    Oct 2003
    530
    If your using the center slot, a D675 will hit the z way cover when the vise is tightened all the way. A D688 will not, it doesn't have anything that protruedes from the front of the vise when tightened. Make sure you get the D688!! It's not much more, and it is a nicer vise. Btw, the Kurt speed handle clears everything.
    Sep 2007
    97
    Yeah the 688 is the one I ordered. I'll check on the 5/8 keys too. Thanks guys.
  1. Home Made Vise Stop - For 6" Kurt Vise
    By widgitmaster in forum Bridgeport / Hardinge Mills
    Last Post: 12-15-2006, 03:49 PM
  2. WTB 3-way angle vise
    By bherr in forum Shopmaster/Shoptask
    Last Post: 05-31-2006, 09:34 PM
  3. Vise Advice
    By split63 in forum Uncategorised MetalWorking Machines
    Last Post: 04-17-2006, 03:01 AM
