586,123 active members*
3,433 visitors online*
    Sep 2007
    17
    Can these stepper be used?
    Hi All,
    I have 3 old xerox Sanyo Denki motors I think two are 140 or 170 and other is 180 OzIn.
    I would be doing microstepping most of times, no full throttle. What do you say can these be used with Joe's model? Or I have to reduce size of Joe's say 4'x4' or 3'X1.5'?
    Other question I can't get 1/2" screw for such length of X Axis, I wonder if 3/4" or 1" with 8TPI can be used with these steppers?
    Plz help
    P.K.
    Aug 2004
    3215
    Quote Originally Posted by pksdms View Post
    Hi All,
    Plz help
    P.K.
    I would not recomend anything less than 200oz/in motors, (thats what i used for a year) and if you step up to 3/4 to 1" leadscrews (way overkill) you will need even more powerful motors to turn the larger mass.
    Joe
    Sep 2007
    17
    Thanks Joe,
    Why should motors of same strength be used with each Axis, although cutting strenght required with each Axis is same but length travelled is different in each Axis. Should not be X Axis Stepper more powerful?
    P.K.
  1. Wanted DIY stepper driver circuit for 6 wire stepper motors
    By Colin300 in forum Australia, New Zealand Club House
    Last Post: 09-21-2007, 03:20 AM
  2. STEPPER DRIVER FAQ {Stepper/driver amp per phase match.
    By huios in forum Stepper Motors / Drives
    Last Post: 08-27-2006, 02:43 PM
  3. difference between a stepper indexer and a stepper drive
    By pcroxford in forum Stepper Motors / Drives
    Last Post: 11-02-2005, 02:35 PM
