586,106 active members*
3,177 visitors online*
Results 1 to 9 of 9
    Oct 2007
    179
    Denford Cyclone P Fanuc OT
    I have a problem with my Denford Cyclone Lathe. It has Fanuc OT.
    The Z axis will not reference Zero.. when the axis dog touches the first slow down switch it alarms out and says Z axis overtravell.
    I tried pressing the switch by hand before the dog reached it and now it will only go to the position it stopped at which is around 150mm away from the switch!
    Just can't get it to move past this position...
    The X axis zeroes fine!!
    Thanks for any help guys..
    John.
    2932
    Have you tried the old P-CAN trick? Hold the P and CAN keys in while turning on the control. Keep them held in until it's finished firing up. Then try the zero return.
    Oct 2007
    179
    Ok thanks dcoupar I will try this, I'm new to OT having only used 6M/T before.
    How does this solve the problem..does it reset the limit switches..?
    Nov 2006
    925
    Get on to Gefanuc and buy a manual.About £50 IIRC.It will be money well spent in time to come.They sometimes pop up on Ebay.Also guys selling manuals on cd`s on Ebay,cheap but I don`t know if they`re any good.If you search the net for fanuc you will turn up very similar sounding websites,beware as these guys just order the manual from the genuine Fanuc and mark it up.The real one is in Milton Keynes.
    Mark.
    Oct 2007
    179
    Thanks Mark I think I will need it!!
    Managed to get the lathe zeroed now on the Z axis..I wound it to the stop by hand whilst the machine was switched off then powered up and found it zeroed first time...?
    Ran a program and it worked fine...not sure why this should fix the fault..?
    Any ideas
    Nov 2006
    925
    That works sometimes.On most industrial machines it is difficult to access the motors/screws to turn them by hand.I have three lathes with OT`s on them and all the manuals.Touch wood these controls never give me problems.I do not programme,well only enough to check a repair.My son programmes I repair.If you have specific questions PM or email me and I will scan the relevant parts of a manual but they are too big to scan the whole lot.Where in the UK are you?
    Mark.
    Nov 2003
    98
    Quote Originally Posted by cnc-it View Post
    The "P Can trick" will tell the machine to ignore the Soft overtravel limits set up in parameters. This will allow the machine to actually reach the limit switch and properly home out.
    More info in this thread.
    http://www.cnczone.com/forums/showthread.php?t=40774
    bob
    Oct 2007
    179
    Thanks Bob these will be a big help!
    John.
    Jul 2011
    21
    Re: Denford Cyclone P Fanuc OT
    Could someone help me to know the part number of the turret encoder for denford cyclone lathe?
    Somebody take it out for repair and i can find him out.
    Best regards
  1. Denford Cyclone Parameters / Manual
    By Bakes144 in forum Fanuc
    Last Post: 03-28-2014, 10:37 PM
  2. Denford Cyclone Fanuc OT
    Last Post: 11-08-2012, 06:39 PM
  3. Want to buy denford cyclone/mirac
    By scotty1 in forum Want To Buy...Need help!
    Last Post: 02-18-2011, 10:07 PM
  4. Denford Cyclone Any help would be greatly appreciated.
    By Bill Gillen in forum Benchtop Machines
    Last Post: 08-16-2010, 09:40 PM
