586,108 active members*
3,250 visitors online*
Page 1 of 3 123
Results 1 to 20 of 44
    Dec 2006
    11
    Techno cnc Lathe
    Hi all.
    Our school just purchased a new techno CNC Lathe. After using it enough to become familliar with it's capabilities I am rather dissapointed with the techno control software. It only supports IN/MIN & RPM and is rather limited in the number of standard codes it recognizes. Also it is difficult to adjust mid program to get accurate diameters. I was wondering if Mach 3 would run this lathe and if so how do I go about changing over? The Techno runs off a special card in the pc with a cable similar to a printer cable but with 50 pins. I currently use Mach 3 mill on a Tormach PCNC1100 in my classroom. I think the consistency of having both machines running Mach controllers would be very helpful to both students and myself. I am a CNC rookie and would greatly appreciate any advise.
    Thanks,
    Dave
    May 2008
    84
    Re: Techno cnc Lathe
    Zombie thread!
    Any updates on this?
    I just bought a used Techno lathe complete less PCI card.
    That card is $550 new, which is probably less than a proper conversion would run.
    Are there any used PCI cards out there left over from converted machines?
    Otherwise, how did you do the conversion ..... way back in '07
    Jan 2007
    723
    Just replace the motors, motor drives, power supply and break outboard to get Mach 3 compatibility.
    I've never done a lathe but I have converted a few routers including a stepper techno davinci.
    http://www.glenspeymillworks.com Techno LC4896 - 2.2Kw Water Cooled Spindle | Moving Table Mill from Omis 3 CMM, 500Lb granite base | Epilog Legend 32 Laser Engraver
    May 2008
    84
    I realize that is an option, and the one most used.
    Right now I have a small mill, and a lathe in that process, but neither is completed, and I have yet to own a working CNC machine. This is strictly a low-budget hobby thing for me, and a learning experience.
    If I can get this one working just by obtaining a PCI card, that's the quickest, simplest way to get it going. It might be limited, and I might have to upgrade to get more functionality, but right now I'd just like to see the spindle turn and the axes move before starting a conversion.
    Call it a confidence-builder.
    Jan 2007
    723
    The only people that I know that would have a card would be ArmorCNC. I think that bought all the old Techno stock before techno closed their doors.
    Dec 2006
    11
    AR1911 I wouldn't waste your money or time on a PCI card. The Techno lathe turned out to be a total piece of junk! After many hours of trying unsuccessfully to get it to work I convinced Techno to send me a new lathe. The new lathe was also non functional. I angrily returned the second lathe and purchased an Ajax with Centroid controller from Forrest Scientific. I am very happy with the Ajax lathe. I have spoken to several Tech Ed teachers I met at a conference who had the exact same experience with the Techno. I have converted a Spectralite lathe and a Shopbot router to Mach 3. I highly recommend that approach for your Techno Lathe.
    May 2008
    84
    Quote Originally Posted by lentzie View Post
    Lentzie, I presume you mean that the lathe controls are junk, is that right?
    If I convert it to Mach3 or EMC, all that will be replaced. Or at least, the main PCB/motherboard. Everything else looks like standard stuff, and of decent quality. The VFD is a nice unit.
    The basic machine seems OK mechanically. The headstock and bearings look a bit light duty, but I suspect it's the same hardware used in the Asian 9x20 manual lathes.
    Dec 2006
    11
    Yes. The issues were with the control system. The lathe seemed ok but I was never able to get either machine to run properly. I have no experience with configuring Mach3 and servo motors, however I'm certain the good folks here on the zone can help you out. I have had success with CNC4PC break out boards and other items they sell. For the type of work I do in my classroom and home shop I can't see any benefit of servo's over stepper motors. There are others who I'm sure would disagree. If you find the cost and complexity of setting up the servos is prohibitive you can purchase steppers for about the price of that PCI card. You have a nice platform to work with, I'm sure with the help of the Zone you will get it running.
    May 2008
    84
    Would these OE parts have any value on the used market?
    Servos, main board, toroid transsformer - Ebay?
    May 2008
    84
    Really? Techno's site is up, and they have answered questions.
    I think it was sold a few years back, but they do appear to be in business.
    Jan 2007
    723
    Your right they still are in business but not the same as before. Now they hawk Chinese junk instead of the good German/American parts and designs they used to sell.
    May 2008
    84
    ArmorCNC quoted me $850 (!) for a PCI card. Not gonna happen.
    Looks like a conversion is going to be the only sensible route. I like the idea of retaining the servo drives, but I'm not seeing many driver choices, and they are expensive. Any suggestions there?
    I also can't find anything on the servos, except that I have a pinout for the connectors to the main board. They are marked as 50 oz-in, which seems pretty light for theis size machine. Everyone says go to steppers, but that seems like a step backwards. (no pum intended)
    As for the quality, while this appears to use Chinese 9x20 parts for the bed, cross slide and tailstock, possible the spindle. the balance of the machine appears to be well-made from good componenets - US-made servos, Baldor 3-ph motor, quality VFD etc.
    Jan 2007
    723
    That is about the same price I bought mine for about 7+ years ago directly from techno. I bought a lc4896 super cheap with out the card.
    My lc4896 uses the same servos! They don't seem powerful on paper, but I have broken quite a few 1/2" shank bits with their combination of servos and ball screws!
    Servo drives are expensive compared to stepper drives and require tuning to the servos. How is the rotational motor powered and rpm's measured?
    May 2008
    84
    Techno says they have the PCI cards in stock for $550.
    May 2008
    84
    The rotational motor is a Baldor 3.4 HP 3-phase 230V powered by a 115V VFD.
    There is a speed sensor/encoder of some sort
    Jan 2007
    723
    Jump on that!
    May 2008
    84
    Quote Originally Posted by Pplug View Post
    Jump on that!
    Well, when I read that others dump the OE software because it's limited, I'm hesitant to invest in the hardware to run it. If the card were half that, I'd do it.
    I think the correct course for me is to change to steppers and use Mach3 or EMC. But I'll pursue some other projects and see if a PCI card turns up. In the meantime I'll try to figure out what drivers etc I want to use.
    I do appreciate all the input, and more is welcome
    Rex
    Feb 2013
    164
    Did you by chance pick this up in the DFW area?
    Sent from my SM-G920V using Tapatalk
    May 2008
    84
    Quote Originally Posted by zamazz View Post
    Yes I did. It has been on CL for months
    Feb 2013
    164
    I was planning on looking at it last Sunday, but you got there before me. That single board set up scared me though, so I wasn't going to offer much. If it had individual servo drives it would be much easier to retrofit.
    Good luck with whatever route you take. I'm partial to mesa boards and Linuxcnc if you decide to retrofit. If you're near Dallas and ever need help let me know.
    Do you know what voltage the servos are?
Page 1 of 3 123
  1. Techno CNC Under New Ownership
    By TechnoCNCSystem in forum Techno CNC
    Last Post: 10-24-2013, 04:52 PM
  2. Techno CNC Help Please!!!
    By stevec in forum Commercial CNC Wood Routers
    Last Post: 11-18-2012, 02:33 PM
  3. Post Processor For Techno CNC Metal Lathe
    By Hodgson in forum EdgeCam
    Last Post: 01-17-2012, 11:07 PM
  4. techno
    By cabnet636 in forum Commercial CNC Wood Routers
    Last Post: 06-16-2011, 10:23 AM
  5. Techno vs K2
    By big_mak in forum Techno CNC
    Last Post: 09-09-2007, 10:20 PM
